Protomotive 997 Tip drag result
AUEturbo,
Those are stunning numbers. We look forward to duplicating those numbers with "The Gladitor " ( with one intercooler duct taped shut )
https://www.6speedonline.com/forums/997-turbo-gt2/224580-68mm-billet-turbocharger-build-champion-motorsport.html
Shotcaller -----> Your next
AUEturbo,
good number but with this kit , you should have between 10.1 10.3 max
you should dyno your car and check if the car giving you the same hp numbers<!-- google_ad_section_end --> <!-- / message -->
I have used Dynocom dyno.
My stock 997TT dyno'd 379 WHP on it.
Dynocom reads lower then most AWD dyno's.
It is considered a heart-beaker, depends on how it was calibrated.
From my experience, there is not a whole lot of "skill" involved when launching a tip Porsche.. So, I'll go with, "his car is not performing like it should if in fact he is running full boost."
AUEturbo,
Good luck with "The Gladitor ".
Hi Besiktas
did you get better result going from 71's to 76's?
Can stock injectores support up to 1.7 bar?
thats why i bought 80lb injectors to boost more
btw , i took your advise and installed whiteknight upgraded gearbox ,, its great ..
10-06-2015 04:43 PM
