In a search of the best Turbos for my 997.1 TT
Old 11-01-2010 | 04:07 AM
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Originally Posted by skeeter
I found these a while back when searching...I believe these are simular to the turbos that switzer uses...They use all the factory parts to bolt on...I called the company a while back and they where still working on the 997...This would be a great solution to buying standard gt30 turbos which requires a lot of work to get them to fit....I'll contact them again on Monday and see how their progressing...
http://www.titanmotorsports.com/tial...30-turbos.html
Those already used by SPI w/911R and Proto PE1000hp kits
Old 11-01-2010 | 09:14 AM
The Bogg's Avatar
Originally Posted by milou
That is a great option but not VTG. I'm looking for a direct replacement of the turbos, i think Champion will do the trick
I think it will cost you about 4 to 5k to upgrade your turbos to get the latest vtg. For about 8-10k you could get Alpha 30s which aren't vtg but will work with stock headers etc... and just require a bit of plumbing. Then you'll get 700whp on pump gas. Something to consider if you're feeling the need for more power than your current upgraded kit. I'm a couple of stages behind you and will stick with vtgs but I did consider the Alpha option too.
Old 11-01-2010 | 10:47 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
You're right.
The only reason i want to stick to VTGs is that i'll have to modd my ICs,add a boost controller,headers (maybe not) etc.
I'm looking for the best VTG kit and i think is the Champion 68mm kit.
I'll wait and see what happens
Old 11-01-2010 | 10:59 AM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
Milou, sent you another PM...
Old 11-01-2010 | 04:15 PM
The Bogg's Avatar
You're right.
My understanding with the Alpha 30 you don't have to mod the IC or headers. It's possible I'm wrong though, I'll go back and look at the email I received.
Old 11-01-2010 | 06:50 PM
Shotcaller's Avatar
Stock headers is fine but the i/c need to modify since u will need Proto/SPI intake system.
Stock intake is damn restrictive with alpha
Old 11-01-2010 | 08:16 PM
The Bogg's Avatar
Ah yes, the fenderwell setup.
Old 11-01-2010 | 09:20 PM
Shotcaller's Avatar
You r right
Actually Todd K made 870whp on Van 997 GT2 w/stock intake system which will cost same as the fenderwell setup...The problem is that stock intake system still restrictive
Take a look
http://www.youtube.com/watch?v=fPMA9iDgoMg
Old 11-01-2010 | 10:57 PM
skeeter's Avatar
skeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond repute
If you get standard gt turbos you will have to modify your headers as well since it has a rectangle port...You will also need to modify your oil/coolant line setup for the turbos as well as having the exhaust modified to fit...The IC will also need to be modified to accept the bigger hoses...The link I posted is suppose to use the stock oil/coolant lines, stock headers and normal exhaust...You would still have to modify your Ic as stated....I think switzer uses something simular to these as you do not have to change all the parts listed...
Old 11-01-2010 | 11:13 PM
farris's Avatar
farris has a spectacular aura aboutfarris has a spectacular aura about
Sounds interesting. I wonder how these will compare to the Chsmpion 68s.
Old 11-02-2010 | 05:06 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
You r right
Take a look
It's a strange thing , that the A/C is on
Old 11-02-2010 | 05:57 AM
milou's Avatar
Maybe its because the fuel lines and A/C lines are touching each other, when A/C is on its lines become cold therefor the fuel lines get cold.
Old 11-02-2010 | 05:31 PM
Shotcaller's Avatar
Ok lets get this straight
1- GT kit ( GT3071R's/GT3076R's ) need to modify stock headers
2- Alpha kit (A3071/3076) use stock headers.
3- Both GT and Alpha kit need coolant kit
4- Alpha kit fit on stock exhaust flange style and GT kit custom exhaust
5- SPI use thier silicon hoses and Proto use stock hoses for I/C's on Alpha and GT kits.
Old 11-02-2010 | 05:34 PM
Shotcaller's Avatar
I believe that Alpha is another highter level
Old 11-02-2010 | 05:35 PM
Shotcaller's Avatar
maybe its because the fuel lines and a/c lines are touching each other, when a/c is on its lines become cold therefor the fuel lines get cold.
+++1111
