In a search of the best Turbos for my 997.1 TT
Old 11-12-2010 | 10:28 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
did you deceied ???
  #47
Old 11-13-2010 | 01:55 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
i have just got my new hot sides from Protomotive, i'll install them soon and letyou know.
Champion 68mm VTGs might me my next mod.
  #48
Old 11-13-2010 | 07:27 AM
ysfg35's Avatar
a3076 .. you can not belive how fast your car gone be ...
  #49
Old 11-13-2010 | 08:41 AM
SpunkyQ8's Avatar
SpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond repute
milou if u could wait, i'd say go wth the 68 VTG's .. great response and less maintance and nice HP
  #50
Old 11-13-2010 | 08:43 AM
The Bogg's Avatar
sounds like you're taking the expensive route!
I'm glad you have them so you can compare the extruded vs non-extruded. I presume that's what the new hot sides are that you are referring to? Can't wait to see your numbers. I saw fastlaw's numbers but I must confess that I was expecting a bit more power for the money, although I note that the extruded version holds it's power higher in the rpm range.
great thread, I'm hoping to get some good info here to also help me decide.
  #51
Old 11-13-2010 | 12:59 PM
Arone997tt's Avatar
Arone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud of
I should be getting my car back with 68mm in the next couple days i will be giving you guys a full write up
  #52
Old 11-13-2010 | 02:00 PM
The Bogg's Avatar
Can't wait! I'm most interested in the numbers with pump gas (I have 94octane here) since that's what I'll be using.
  #53
Old 11-13-2010 | 02:02 PM
milou's Avatar
Expensive route this costed me 1700, the 68mm cost around 5k.
Anyway i had them ordered before knowing about the 68mm VTGs. This is a totally different mod and not at the same level as 68mm, just a little more power around 50WHP, not bad
  #54
Old 11-13-2010 | 02:05 PM
The Bogg's Avatar
I mean expensive route by trying things one at a time, but I saw your post above about not knowing about the 68 upgrade. To be honest, if you're wanting more power than your current vtgs I would think you'd be better off going to something like alpha 3071 which supposedly has little lag and can be setup to be quite powerful for only a bit more money than the Champion 68s.
But I can't wait to hear what you have to say about the extruded hot side compared to non-extruded!
  #55
Old 11-13-2010 | 02:07 PM
The Bogg's Avatar
Oh, and the 68s will give low600s whp with pump gas. I believe the extruded ones you have should be good for somewhere between 550 and 600 of whp and maybe a bit more.
  #56
Old 11-13-2010 | 02:19 PM
milou's Avatar
My tuner said is not about gaining more power with extruded hot sides, its more about holding power/torque high to red line.
As always i will say what really happens, you will know if it does or does not worth it by the end of next week
I believe i will notice and like the difference since Todd has never disappointed me before.
  #57
Old 11-13-2010 | 02:28 PM
The Bogg's Avatar
Todd is my tuner too and hasn't disappointed (although I haven't been able to get a hold of him lately, guess he's busy). If you look at the dyno results on his website vs fastlaw's dyno with extrude you can see that it is exactly what you said - same peak power but instead of the power falling off above 6k rpm it continues to hold up higher. Now is that worth 1700 bucks? I'm not sure it is for me, but still waiting to see some performance numbers before deciding.
  #58
Old 11-13-2010 | 02:32 PM
Arone997tt's Avatar
wil also post vbox #s, since this is what really matters
  #59
Old 11-13-2010 | 02:39 PM
The Bogg's Avatar
that is the truth.
iirc, you didn't have your engine "built" to support the 68 turbos, right? Does that mean you don't have any warranty?
  #60
Old 11-13-2010 | 02:47 PM
Arone997tt's Avatar
no i did not, u really don't need "built motor with 700whp, may be if you where running 3076s, not for 68mm..what warranty?
