Sponsored by: Bears Transport
Intercoolers...997,2 Vs 997,1...Game over...
Old 06-21-2011, 10:07 AM
RS38's Avatar
RS38 has a spectacular aura aboutRS38 has a spectacular aura about
Originally Posted by GTRNICK
Do you have to modify anything to make these coolers fit?
You can decide whether you order the .2 ducts from Porsche also and make it really plug&play or you modify the .1 ducts as mostly shown here which is no big deal.
  #287
Old 06-21-2011, 10:24 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
If I buy the .2 ducts do i need the top and bottom piece's for both sides?
P.S. are the ducts guaranteed to fit?
  #288
Old 06-23-2011, 09:34 AM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
I would like to see this numbers when ambient is 30C....
  #289
Old 06-23-2011, 09:36 AM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
I have been running the 997.2 intercoolers on my 996 tiptronic with alpha 28's....its 100 in houston these days and my iats while crusing are about 108...when i do runs they quickly go back down to 108
  #290
Old 06-23-2011, 09:43 AM
here is my cooler test when ambient was 6C.....
not sure if you can read this but 20C IT at 275km/h, egt 885C
  #291
Old 06-23-2011, 10:08 AM
bad107's Avatar
so jealous of the cold!
I am from Poland! My last name is danziger...
  #292
Old 06-23-2011, 11:05 AM
RS38's Avatar
beginning with 260/270 IAT even drops with good ICs.
as this seems to be DURA V6, I would not trust these egt, they are at least 100 degrees higher for real.
not very much boost and very conservative ignition and lambda you drive!!! bad gas there?
  #293
Old 06-23-2011, 11:09 AM
bbywu's Avatar
You should ask him what he's mods have been done to the car. It is very impressive.
  #294
Old 06-23-2011, 02:33 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
In a few weeks I will do it and send you K.
  #295
Old 06-24-2011, 08:06 AM
RS38's Avatar
IAT only 12 degrees above outside temp is indeed impressive, independent of ignition and lambda!!
  #296
Old 06-24-2011, 11:02 AM
will post log from yesterday, ambient 15C at 311km/h 39C
  #297
Old 08-24-2011, 09:54 AM
gmoney's Avatar
anyone know the part number for the .2 ducts?
  #298
Old 08-24-2011, 02:15 PM
K24F's Avatar
Sorry I do not kept logs,
but by 28/30°C AT my IAT reached the fatal 55°C early 5th when testing a 100-300 from 3rd gear.
By 18°C AT it happens only in 6th.
I'm waiting for <15°C AT to test again, I think it will be OK.
If the 997.2 Ics hold correct IAT till AT stays <15°C it is quite good with my localisation, but if I buy other Ics I think they would be TPC/proto 5", I'm pretty confident with Todd.
Nevertheless of course I will log and share if switch to them...
  #299
Old 08-25-2011, 10:09 AM
GT-TT's Avatar
GT-TT is infamous around these partsGT-TT is infamous around these parts
don't hold your breath about AM ICs being better all around than the .2rs ones.
If possible you should only commit to another set if you test it conclusively first.
The compromise between flow and cooling is pretty damn good in those coolers.
  #300
Old 08-26-2011, 12:39 AM
K24F's Avatar
I'm absolutely sure of nothing about AM ICs, that's why for now I keep my .2rs ones, but I'm sure those are absolutely not efficient enough >20°C if you test 100-300kmh ore some long pulls.
(while they are far more efficient than 997.1 Ics, it's OK)
My goal with Ics would be a set which hold IAT<50°C till AT is under or equal 25°C, I can undertsand >25°C perfs can't hold...
Quick Reply: Intercoolers...997,2 Vs 997,1...Game over...
