It's time for a New Clutch
I forgot exactly when everything was installed...My guess is 6-7k mi. It was a Champ until last year when I was first noticing the symptoms. EVOMs 600 tune has ALOT OF TORQUE!!!!
I have 17K on stock clutch. Had the EVOMSit 580 tune done about 500 miles ago. Just started to notice slippage in 5th & 6th when rolling into the throttle. All other gears don't seem to be affected. Im not an overly 'aggressive' driver i.e. don't pound it off the line. Was told stock disc is ok just need to upgrade to the stage 2 pressure plate. Local shop just did stock replacement on another car $2200 drive out.
Andrew, i have the Sachs stage 2 clutch as part of my conversion, it's a similar feel to stock. You are welcome to drive it sometime and see how you like it. So how do you like that Evo 580?
guys remember if the flywheel is scored up real bad or warped at all from excessive heat and slipping. it will need to be replaced as most places dont have the equipment or skills/knowledge on how to turn a DualMass Flywheel so here is the first 1000$ for stock or aftermarket LWF
the next order of business do not get less then a Kevlar, or Fibertuff faced clutch with a sprung hub. if you do your essentially buying an inferior product to current technology on the market.
The sachs 999 pressure plate i believe is the strongest and it can also be modded for more clamp load. pair this with a kevlar or fibertuff disc and you will have a clutch thats gonna hold up to ALOT of abuse into the upper 700whp range where mechanically you need to be diving into twin disc territory unless you can handle the on/off switch type engagement of a Ceramic Disc.
almost forgot none of these upgraded pressure plate will make the clutch harder to move unless you have done the gt2 conversion to a manual slave cylinder. but some of the clutches might have a different engagement point.
Ive used and abused alot of clutches over the years and had some custom designed for cars that were never intended to make power. dont cheap out on the only thing inbetween your motor and the transmission putting the power to the ground that 12-20hrs of book time labor adds up pretty fast when you do it twice
Doug, thanks for the offer sounds like a plan. I'm still a little ways off from doing it(hopefully) As for the EVOMS 580. Being able to watch Todd Z personally do the flash and understand what he was doing and why was great and the result....well its just silly Im still geting used to it and the exponential power from stock without any compromise. It just flat hauls butt
OSI
Naturally i will replace the clutch disk at the same time, my comment was indicating that the Porsche OEM clutch disk was of sufficient quality that an after market disc wasn't necessary for my application.
OSI
04-28-2022 12:38 AM
