Tires!!
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
BTW, thanks for the info on your web site. My table would not have been possible without Tire Rack's info.
Glad my tire weight ranking table is helpful. It was a slow day at work --
. Anyway thanks guys for the positive rep remarks. I too am surprised that tire weight does not come up in every tire review or discussion. Almost never discussed as a matter of fact.
Abdullah (cayenne_USA) is of course absolutely right. The tire adds weight where it hurts the most - the outer part of a wheel. Further distance from hub means higher angular momentum, and large angular momentum affects steering, acceleration, and braking.
If the rudimentary physics I took at Berkeley has taught me correctly, the higher mass itself increases (linear) momentum, the up and down motion of a wheel on the road (as oppposed to the rotation of the wheel), and this affects ride and handling as well.
Essentially every critical parameter of a good sports car is adversely affected by mass at the rim, tire, and brake, aka unsprung mass.
![Big Grin](https://www.6speedonline.com/forums/images/smilies/biggrin.gif)
if you can get a set of MPSC for $1000 like you told me don't miss this deal.
WheelB
991 Turbo Vendor Classifieds
07-23-2018 09:37 PM
WheelB
09-03-2015 10:26 AM
