Jackpads?
Old 12-19-2010 | 12:46 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Jackpads?
Anyone use them/source?
Old 12-19-2010 | 12:48 PM
996PCarGo's Avatar
996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold
Arrow I'm...
...planning to give these to myself for the holidays...
http://cgi.ebay.com/ebaymotors/PORSC...item3362f1f649
Old 12-19-2010 | 12:49 PM
bbywu's Avatar
Hockey pucks.
Old 12-19-2010 | 12:54 PM
bonehead's Avatar
Originally Posted by 996PCarGo
Saw those. I assume all 997 jackpoints are the same?
Originally Posted by bbywu
Hockey pucks.
Hockey isn't that big in the desert. Wiscaansin....I'm sure you have pucks comin' out ur ears.
Old 12-19-2010 | 12:59 PM
bonehead's Avatar
What about this one? Rennline is one of my favorite companies.
http://www.rennline.com/Jack-Plate-L...oductinfo/T02/
Old 12-19-2010 | 01:27 PM
mllarson's Avatar
mllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant futuremllarson has a brilliant future
These work really well with my ESCO Jackstands, and floorjack:
http://www.hockeygiant.com/wheels--b...key-pucks.html
Old 12-19-2010 | 01:37 PM
bbywu's Avatar
Hmm...looks like hockey pucks.
Old 12-19-2010 | 02:22 PM
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
I am with Bob - I bought 4 hockey pucks at sports authority for $5 and use them with low profile jacks from Costco with absolutely zero problems. It clears stock car by 1" or so you may have to drive up 2x4 if your car is slammed.
Old 12-19-2010 | 03:02 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
I purchased used pucks on e bay. I think I paid like ten bucks for thirty used ones. Then I made and modified some jack stands with the pucks.
Old 12-19-2010 | 06:52 PM
jhbrennan's Avatar
If you just need one, PM me your address and I'll send you one of what I use. Here's a pic - the one I have is silver - bought them for my Vette 4 years ago and they work just fine with the 997. I bought in a 4-pack but I only use one.
Old 12-19-2010 | 07:05 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
I'm used to be a hockey puck fan. But I have a set like the ones 996PCarGo showed over at EBay and they seem worth it to me. There's some value in having them lock in place, but I particularly like that if the chassis mounts begins to deform, the center of the aluminum jack pad will touch the chassis before the bracket deforms too much. Seems like goodness and something the puck won't do. I've since purchased an equivalent set for my FordGT for the same reason.
HOWEVER, I have lowered the car from the jacks and driven away without removing the pads from the brackets on the car. Of course, I'm sure I'm the only one who has done that. Surely...
Old 12-19-2010 | 07:07 PM
bonehead's Avatar
PM sent and thanks!
All good points, and I'm pretty sure you're not the only one who has not unlocked them before driving off
Old 12-19-2010 | 07:25 PM
vpmick's Avatar
vpmick is infamous around these partsvpmick is infamous around these parts
you can search ebay under "porsche jack pads" and see many types. I bought one from GQ Industry off ebay because it was advertised as 35% larger than competition. It is still very small but looks like it will work fine. Very high quality. I only bought one as that is all I need to change tires and other DIY maintenance.
Old 12-19-2010 | 08:21 PM
bbywu's Avatar
Thumbs up
+1 rep for generosity.
Old 12-21-2010 | 10:26 PM
neuroguru's Avatar
neuroguru is infamous around these partsneuroguru is infamous around these parts
I have the Rennline jackplate and tie-down (haven't used it yet) and the locking jackpads. The jackpads are ok, they are a bit floppy, but do the job. You have to remember to remove them as noted above. I have four for using a lift, but generally use a racejack and one at a time.
Jackpad
http://www.rennline.com/Jack-Pad/products/395/
Tie down
http://www.rennline.com/newssection.asp?dept=836
