Sponsored by: Bears Transport
Turbo Timer?
Old 06-24-2014, 02:18 PM
sidwin's Avatar
sidwin is infamous around these parts
Originally Posted by venkatreddytx
The turbos on the 997TT are oil and water cooled unlike the 300ZX and Supra which were oil cooled only.
Convention current keeps the water moving slowing after shutdown and prevents coking of oil.
This is the reason you do not need a turbo timer on a 997TT.
Hope this answer you question.
that's not true. supras are both oil and water cooled turbos. aftermarket turbo kits are usually oil cooled only but if you are dual ball bearing then once again oil and water cooled.
turbo timers might not be needed but it surely makes most people feel better and has the cool factor when you walk away from your car that is still running
sid
Old 06-24-2014, 02:27 PM
jhbrennan's Avatar
sid
You're really resurrecting the old stuff - looks like most TTs stayed cool enough without timers - at least since 2010.
Old 06-24-2014, 02:29 PM
sidwin's Avatar
so after a long drive i hear the fans coming on. is it better to simply open the trunk and let the engine bay cool down is it better to have the fan run? i drove 1550 miles this weekend picked up the car in NYC and drove to New Orleans. that was some heat and brake dust...
sid
Old 06-24-2014, 02:31 PM
jhbrennan's Avatar
sid
You'll get mixed answers. The fan blows air into the engine compartment directing heat downward. Folks who advocate leaving hood closed think it's better to have the heat from the exhaust system directed downwards as opposed to having air exiting upwards over the engine when the hood is open. Personally I open the hood and use a floor fan to direct heat out of the garage.
04-28-2022 12:38 AM
COBB Tuning
01-29-2022 09:42 AM
Christian
08-24-2015 12:56 PM
johnny.dangerous
08-21-2015 10:48 AM
PelicanParts.com
08-20-2015 02:57 PM
Quick Reply: Turbo Timer?
