Europipe Stage 1 install
#31
Just got my EP1 installed today, off came the Cargraphic Export version. I decided to remove the Cargraphic once it started tripping post cat CEL's.
As far as sound goes the Cargraphic was louder buy a decent margin, the EP1 is quiet however it makes itself well heard at full throttle. Subdued at 70 mph cruise, no drone, but throaty at full throttle is quite an achievment and this exhaust should suit the vast majority of Turbo owners. I wish it was a wee bit louder (my turbo is not a daily driver), the EP2 is probably perfect for those who dont mind it louder.
During startup its loud, but on par with the Cargraphic, its common and a requirement to get the cats heated up quickly.
Packaging was fantastic, this exhaust will travel half way around the world and show up just fine. The box alone probably cost $50 or more.
Now on to the good stuff, performance. There is a noticeable difference in how quickly the boost comes on with the EP1 vs. the Cargraphic. The turbo whistle is also considerably louder, music to my ears. With the Cargraphic and EVOMSit flash there would be a 50/50 chance you would hit overboost at lower rpms (you had to be very quick with the throttle stabs) however with the EP1 and their 100 cpi cats the turbos spool up faster and it hit overboost every time I tried it. I thought this was a very interesting difference between the two. I dont think peak power is any different but the boost hits harder, earlier with the EP1.
#32
Note however that when the car is cold, it does sound close to the video. Loud and raspy. It lasts a few minutes, until things get warmed up, so I guess its just long enough to wake the neighbors! Sometimes it makes me wonder if I would have liked it as loud all the time. That sound is also very intoxicating.
You can stop this cold start raspy/loud problem, by turning off the engine after starting, waiting a few seconds, then restart. The fast idle and tank-like sound disappear. This way you can quietly leave garage and driveway.
#33
The fuel system and other diagnostics are finished only after a proper catalyst warm up is performed, after which errors are detected.
https://www.6speedonline.com/forums/...8&d=1308284571
#34
Here is the EUROPIPE installed on your 997 Turbo. The EP system is an absolute work of art and the fit and finish is excellent and of the highest quality. Much respect to Stef and Herman. Enjoy the new system gmoney, was good to see you. -B
#36
Nice to hear that you enjoy the new exhaust. The turbo whistle becomes more prominent as the boost pressure increases. Driving uphill in a low gear at 2000-3000 rpm is a feast for your ears.
As soon as you release the throttle the exhaust will bark. This barking is much more noticeable on the outside though. So let someone else drive your car so that you'll know how it sounds on the outside.
Cheers from Belgium!
#37
Found this tank-like sound can be avoided by turning off the engine for a second before restarting. This slows the engine speed down as well as aborts extra rich gas to air mix causing this tone change. As I remember back, the stock system too sounded a bit louder and different on startup but not so bad.[/QUOTE]
I assume only woman and neighbours don't like a tank-like sound right?
Hope these interrupted cold starts won't cause backfires...
#38
Hope these interrupted cold starts won't cause backfires...[/quote]
Never thought any harm could come from interrupting cold starts....never get backfiring, but do drive the turbo slow for awhile thru neighborhood. Harm or not, my turbo gets started twice. Hey, I like your EP1 performance/sound on the road. Gives a sound the 997.1 seriously needs, and all this with no flashing engine light! But the cold start in a partially closed garage is even real rough to me. However I keep windows up until the second start.
#40
The respect is mutual!
Cheers from Belgium
#43
The maximum backpressure on your previous Cargraphic exhaust is 0.29 Bar/4.2 psi, with the EP1 the maximum backpressure is 0.18 Bar/2.6 psi
#44
The boost comes on more quickly because of the lower backpressure of your new Europipe exhaust. More boost = more tq/hp at low rpm and midrange = quicker acceleration
#45
I've had my EP exhaust on for about 4 months now. I enjoy it more every time I drive the TTS. I did the install myself, and can't say enough about the excellent fit and finish, and about the outstanding support from Stef.
The only down side- the Belgian chocolates are gone and those damned things are addictve.
