Mustang Dyno Run
Mustang Dyno Run
Dynoed my car on a Mustang AWD Dyno on a cold day in January.
I am/was impressed with the results.
574WHP = 700CHP(assuming 18% driveline lose)
620WTQ = 750CTQ(assuming 18% driveline lose)
Car running on E85/Protomotive Tune and driven daily this way
Note:
Dyno shop had no fans to blow air onto the intercoolers, saw an IAT of 70*C
in the logs made of the runs.
Note:
What surprised me was not seeing the drop in power past 6500 rpm that I have
seen on most other modded VTG turbo dyno graphs.
Car feels awesome and boost start building by 2000 rpm, afraid any upgrade my introduce lag.
Need to upgrade the fueling system if I run bigger turbos on E85, so am leaving the car as is.
great results .. could you please show us 100-200
i think your car in 6s ...
nice car bro ..
rep for you
nice car bro ..
rep for you
So you might consider a kit like a Switzer P800 if you ever want to upgrade without introducing more lag. Like you said you would have to do a new fuel system to continue with E85 though...
You can actually run a kit with tial A28s with less lag. Look at this volumetric efficiency graph from TTDude. He runs proto modded VTGs.
I am pretty sure A3071s will have more lag than VTGs. The A28s with good supporting mods can match power of 3071s with much less lag.
Thanks Scott.
The torque hits hard peaks and holds from 3500 - 4500, makes the front end go light and the rear steps out when I get on it.
