so I dynoed my car today on maha....
#123
so I bought 3 pieces
#125
don't remember but as I remember my ecu guy reduced fuel pressure....or maybe not, don't remember.
as stock are up to 700ps those are at the begging.
#129
there is one in my avatar showing one liquid cooler.
coolers:
two liquid coolers and heat exchanger produced by company provides radiators for redbull racing f1 team.
engine:
garrett turbos
external westgates
external blow off's
camshafts
injectors
no maf's
con rods
ecu
custom headers
76mm exhaust
spec map sensor
I think that is all.
#130
There is no boost fall of or leaks! Boost on this tune is being controlled by the ECU, not the wastegates, fixed boost tuning is the easier thing to do, controlling boost with the ECU is the tuner's challenge.
His ECU tuner could go all the way up to 2 Bar if he wants at 4K RPMs, and then modulate boost to end at 1.5 bar at 7k RPMs and 1000HP for instance.
#131
my ecu guy asked me before he tune the ecu how I'm planning to use the car?
I said "I will do Le Mans 24 Hours race"
he said ok.
btw I'm still running with stock pistons, in his opinion this is absolutely max for them as pressure in combustion chamber is much higher....
#132
Because of this I'm very interested in knowing more of your car's intercooling solution.
( I have a narrowbody car and there's yet no IC ducting to IC's, just outlets. Inlets are slightly tricky to build.
So far I haven't heard about a water-to-air IC that can take track use more than few laps...would like to get ones, would make a nice sleeper... )
#133
#134
It is a 5-6 yr old protomotive build with custom engine dyno tuning, 3.8 ltr, twin plug, no MAF, Garretts (old T04), IC, mechanical rockers, equal length headers, all internals upgraded. Car is 2WD, run made in 40C at less than 1.1 Bar and 1 shift. Injectors max out at 1.2 Bar because the car is for street/ track usage.
#135
it's very difficult to build good working system.
but there is a lot of cars running with liquid systems, veyron for example.
PorscheEnthusiast
11-13-2015 02:23 PM
09-01-2015 03:16 PM
