GT3 Front Air Vent - The Smile on a 997TT
#31
So what is the correct oem distance from the hood? Skandalis it's 5mm but I see other pics that is almost at the edge..
Also nobody has mentioned the downforce function and the radiator cooling feature which also requires some more parts to position the radiator correctly tom take advantage of the part (and apparently reduce drag).
#40
#45
prochipharma,
I'm not sure if I understood your question properly, but the installation video for the rennline unit shows brackets/clips, and no glue AFAIK. It does, however, leave what looks like a big gap between the smile and the hood.
