Aftermarket Diverter valves
had the Agency Power ones on my car for a month, (got them for free from a friend) brand new in box and I at first thought it was beneficial, because the boost seemed to stay up when i was shifting, but i ended up doing a readout of my computer and found that i had a boost leak.... I thought it was something else at first but then I decided to put back the oem brv's recheck the code and it was gone... so my observation is that the AP brv's caused a boost leak, no issue since.
That doesnt mean that other BRV's dont have good results, just didnt have good results with these.
Hope that helps
Hope that helps
Hope that helps
Hope that helps
i've felt the different !
when changing gears slow you'll lose the boost pressure quick with the BOV's it will keep the boost pressure longer when you shift you dont need to boost up from zero there will still be spool in them
when quick shifting you'll see the bar goes down slightly hope this helps
Quote:
Which brand did you use?? and did it improve acceleration numbers?
ECS Tuning - VW
09-08-2015 12:54 PM
