Software options
Software options
I know this has been discussed ad nauseum, but I think it gets derailed every time.
I have an 08 997tt (997.1) WITH a tubi exhaust.
I'd like a 'tune'. I realize that the 'best' tune would be sticking it on a dyno, adjusting per my car, yada yada, I get that. But I'm just looking for a 'bang for the buck' little performance mod. What's the best option? Softronic? Does packaged software account for modifications such as exhaust? (Or will it even matter...)
Help me out here guys, and lets try to keep it simple.
It's super easy to remove the ecu and we have folks send them into us all the time:
http://sharkwerks.com/porsche/techni...2-and-gt3.html
It sounds like you want to just keep it simple and not drill down into the minucia of how one tune might be better than the other. The tunes will account for your exhaust. There are basically two methods of installing a tune--bench flash or OBDII flash. With bench flash you remove the ECU (easy DIY). The other, you hook your computer into the OBDII port and upload the tune file (also easy DIY). The advantage of the latter allows you to easily switch back and forth between stock and flashed tunes without having to remove your ECU each time. That said, convenience is just one consideration. Customer support, future development, etc...are more important factors, imo, and should all be considered when going down the road of mods.
OBD port flashing carries some risks if you do not do it correctly - any interruption in the flashing can brick your ECU. Antivirus software, screen savers, background programs need to be turned off. No internet disruptions, power supply to the vehicle and the computer, etc.
If you brick your ECU, you'll need to send it to the tuner to bench flash.
bob
bob
bob
bob
Good point. If you brick your ECU (and it has happened to several folks), you will be sending it in. It also may depend on your operating system too. I'm using Windows XP with antivirus software running and so far, no problems. I don't think internet is an issue as long as you have the intact file safely loaded on your computer since it's just a direct upload from your computer to the ECU. Power interruptions is a definite problem.
bob
Isn't there a huge advantage to the modifications that allow one to change their tune without taking the ECU out of the car?
I see the valet program and the 91, 93, 100 octane programs as a real benefit. When I do this to my car I am leaning to a solution that can provide this feature. Is there any reason not to go that way???
Even if you send an ecu in by courier you're going to be unable to drive your car for at least a couple of days. I prefer the obdII programming and it gets you a durametric cable too so you can learn things about your car and reset some cels. I've never turned off antivirus etc... and have had no problems but as always ymmv
