Service light vs non-factory 997.1 turbo exhaust
#31
Clearing a DTC only temporarily erases the code..not the problem.
Emissions test will FAIL even with out a CEL indication.
The Europipe differs in construction from other catalyst manufacturers by equalizing the surface diameter (physical surface increase) which is bigger than the stock 600 cell catalyst converter-to the proportionate reduction (greater exhaust flow) of cell cpsi.
#32
I put these on and my CEL problems were gone with my aftermarket exhaust (997.1 tt with speedtech exhaust). Took me about 20 minutes to add this to the O2 bung port. All you need is a floor jack and a wrench.
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
#33
I think the 997.2 is a lot more sensitive, the bungs may not be enough if you have a CEL prone exhaust. You really get what you pay for, as far as exhausts go, on these cars I've learned.
#34
#35
http://www.harborfreight.com/3-8-eig...nch-97177.html
oddjob142
08-19-2015 12:27 PM
