Switzer R911 Alpha Build
#109
Yes it's the normal switzer setup...The Monster Ic...I think there at least 5" or more ahah! They look huge! Same ones they use for all their setups!
#110
It all depends how much power you want to run. For vtgs, an upgrade in injectors will allow you to run both E85 and gas. For Skeeter's build, he mentioned that he's going to run E85 only which means he's likely upgrading the entire fuel system to accomodate the greater flow needed to achieve the desired 1K hp goal. The much larger injectors needed for this are likely too large to handle gas since the equivalent quantity of gas needed is much smaller, especially at idle.
John H
#111
Excellent choice. Some say they are loud but when you have a race exhaust what does it matter.
#112
What's that stock fuel pump capable of in gas or E85? Are you saying the stock pump can support a VTG upgrade on E85? I've never seen limits posted for the stock fuel system. Is a ProEFI or another standalone/piggyback required to run E85 or can this be in a tune flashed to the stock ECU? I realize it would have to compensate for the various levels of ethanol through the different seasons as my understanding is that E85 isn't always 85% ethanol from winter to summer.
John H
John H
Stock Pump Specs
372 Flow rate at 3 bar (n-heptane) <O</O
543 Flow rate at 3 bar [cm3/min]<O</O
SxT Design<O</O
E Type<O</O
25deg Spray<O</O
0deg angle<O</O
12 Ω Coil resistance<O</O
0 280 158 123 Part number<O</O
#113
It's great that your car will be flex fuel. Really interesting, congratulations to you. Do you have any pics of your build with the components being used like the fuel system, what kind of turbos, etc....The build is interesting but this thread could use some more details if you're willing to share. Can you describe exactly what was done?
#114
R911 ALPHA PKG
850 WHP RACE GAS PKG
The Switzer GT2 R911S takes the firm's well-proven P800 GT2 package and pushes it further. Using race fuel, the R911 delivers well over eight hundred horsepower at the rear wheels - 50% more power than Porsche's flagship GT2 RS, with Switzer's MONSTER intercoolers ensuring consistent engine performance lap after lap.
With a (conservative) 911 hp on tap, virtually nothing in the world can pass one of the Switzer R911S 997 TT Porsches.
• SWITZER TURBO-BACK EXHAUST
• SWITZER BPRS SYSTEM
• SWITZER COMPETITION-STYLE HEADERS
• SWITZER ECU SOFTWARE
• SWITZER HIGH-FLOW INTAKE ASSEMBLY
• IRIDIUM PERFORMANCE PLUGS
• SWITZER HIGH-FLOW FUEL INJECTOR SYSTEM
• FUEL SYSTEM UPGRADE
• SWITZER SILICONE HOSE KIT
• TiAL BILLET BOVS
• SWITZER-MODIFIED ALPHA TURBOS
• HD WASTEGATE ACTUATORS
• SWITZER MONSTER INTERCOOLER SYSTEM
• SWITZER BILLET ALUMINUM INTAKE PLUMBING
• ELECTRONIC BOOST CONTROLLER
#115
That's definitely a mouth watering set of mods. It will be an awesome set-up. The standalone is definitely intriguing. Will the Proefi support all the other can bus instrument cluster operations like abs/pasm, etc..as the Bosch 7.8 on the dash or is there some loss of functionality? For instance, I don't think a Motec would.
#116
It's close to 60lbs at 3.8 bar. You can run E85 with vtg upgrade but you'll need larger injectors and possibly upgraded FPR to 5 bar depending on set-up. Venkatreddytx and twturbo have done this https://www.6speedonline.com/forums/...5bar-fpr.html/ and https://www.6speedonline.com/forums/...ml#post3054419 There is no need to run standalone for E85. When programmed correctly Bosch DME can handle it. Skeeter's doing it because that standalone utilizes an ethanol sensor so he can dump in anything he wants and not have to worry about it. There are also no worries about the seasonal variance in E85 with Bosch DME since ECU can easily adjust within that range.
