Check engine codes please help!!
I was driving around with a friend today, I had the car on sport mode and pushed it on full throttle, that was when I got a check engine in the dash, after a few seconds in disappeared.
I went home and put the car on diagnostic, I had two fault codes - P003 random/multiple cylinder misfire detected upper limit valve exceeded
P0603 internal control unit keep alive memory (KAM) error
Upper limit valve exceeded
Thx
Thx
could be, or also plugs? But what diagnostic tool was used? Note these codes 'may' be specific Porsche ones vs. generic OBD codes, some of the codes can be manufacturer specific and I think those ones can be vs. generic codes.
It says clearly multiple misfiring, this is why I think is the fuel. I changed spark plugs last year, I think I have 15000kms on them now. How long do the spark plugs last on modded turbos?
Milou I have gotten this a few times, one was recently. Always same reason really; bad fuel and/or worn plugs.
As for the plugs with your boost and power you should change every 5k kms or 7.5k. Everytime I ve held them more on mine we saw them damaged.
You can bet that the misfires came because of bad fuel and usually when that happens its time to change the plugs.
Stock sparkplugs won't last long
Mini George
07-29-2019 12:20 PM
Mini George
01-18-2016 09:16 PM
tropicatango
10-14-2015 11:32 PM
