1/4 mile time
Old 06-12-2011 | 06:31 PM
topspeedua's Avatar
topspeedua is infamous around these parts
1/4 mile time
Hello. what is the right 0-60 and 1/4 mile time for a stock 997.1, tuned 997.1?
I have cat deletes and a flash and I am doing 3.2 sec 0-60 and 11.1 1/4mile at 124 mph.
Old 06-12-2011 | 06:42 PM
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
Those are very respectful numbers with just two mods. Do you have a manual or automatic?
Old 06-12-2011 | 06:58 PM
topspeedua's Avatar
it is automatic, tiptronic.
rear tires spin too much this is why i loose too much on launch. any idea how to make the car 50-50 split on launch?
Old 06-12-2011 | 08:13 PM
PSTT07's Avatar
PSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nice
Very nice, what was your 60ft time and which flash do you have?
Old 06-12-2011 | 11:55 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
That's impressive time.
I ran 11.3 at 129.5 MPH with protomotive flash and cargraphice race exhaust on MS109.
My 60 feet was 2.2 sec
Old 06-13-2011 | 02:45 AM
dyc1077's Avatar
dyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud of
Any launch techniques to share? How high do you rev up to for launch? I am assuming brake boosting
Old 06-13-2011 | 05:00 AM
topspeedua's Avatar
Hello. I measure all this with racelogic, but I have my own Raceamerica timing system (we organize drag events in Ukraine) and I compared it many times and recelogic is very accurate vs Raceamerica timing sysmem.
I did not made a note to 60", I will do it today when I mesure 1 mile time if it is not gonna rain.
It is a european company flash, for decat exhaust. i have stock exhaust with cats removed and flash. other then that the car is stock.
Launching - i always do like this:
turn off traction, then put it in sport mode, press SPORT button, then all the way brakes and accelerator, car is start to make boost (i didnt noted rpms but i bet they are around 3000) and at 6psi-9psi i release brake and car launches. The car is in sport mode and display shows boost at 17.5 psi all the way during the run. I will make a log of boost vs rpm today also if my software can log it. i will try. AFR also.
rear tires start to spin too much as i am doing it on a regular road (we don't have race track and even my drag car, Skyline R32, 1200hp, 8.9 sec 1/4 mile, are driven on regular road no glue here in Ukraine, which is a record holding drag car for last and this year still)
Then when it hits the limiter at 1st gear it kinda stops for a .1sec (like hitting rev limiter), then shifts into 2nd and goes on. I bet I need to flash the transmition ecu to remove this loss during 1-2 shift? anyone experienced this bog between 1-2 shift when it gets into the limiter and closes throttle? how can it be fixed?
I can share the flash if anyone is interested, I have a binary file and if anyone here is doing the flashes himself we can compare to other flashes.
Old 06-13-2011 | 10:50 AM
The Bogg's Avatar
Nice work Abby! Do you have any results on pump gas? I've just been pboxing with the Proto flash but not 1/4 mile.
Old 06-13-2011 | 11:23 AM
Abby997TT's Avatar
Thanks Bogg.
My best time on pump with a little mix of ms109 was 11.9@124 I believe. And that was my first time at the track.
I don't drive my car on pure pump gas, it's not fun lol
Old 06-13-2011 | 11:47 AM
topspeedua's Avatar
I just did many runs.
i always make it 3.1 sec 0-61mph, and 11.1-11.2 1/4 mile. my 60' is 1.9-1.8 all the time.
The mile run is 28.7 sec at 175 mph.
Old 06-13-2011 | 12:05 PM
Abby997TT's Avatar
That's very impressive time consider you only have a flash and modded stock exhaust on pump fuel. I am thinking tipttonic is a big plus for drug racing.
Old 06-13-2011 | 02:31 PM
LosPer's Avatar
LosPer is a jewel in the roughLosPer is a jewel in the roughLosPer is a jewel in the roughLosPer is a jewel in the rough
lol, Freudian slip?
Old 06-13-2011 | 03:09 PM
The Bogg's Avatar
Old 06-13-2011 | 05:30 PM
Abby997TT's Avatar
Originally Posted by LosPer
lol, Freudian slip?
My Iphone must of changed it for me LOL
Old 06-15-2011 | 12:56 AM
2fas4u's Avatar
2fas4u is infamous around these parts
Wink NO no!
Ok boys no drug running or drug racing and that's final!
COBB Tuning
01-29-2022 10:42 AM
The_Ruski_Driver
10-25-2015 09:40 PM
gulf gt
08-27-2015 11:27 AM
vbb
08-21-2015 11:17 PM
