Speaker grill cover vibration
Old 07-18-2011 | 04:51 PM
mm450exc's Avatar
mm450exc is infamous around these parts
Got this vibration on the passenger side speaker grill cover. How do you take it off? Anybody had this issue?
Old 07-18-2011 | 05:17 PM
gmoney's Avatar
More common than you would think.
Remove rear panel, instructions in the 997 forum...very easy. With panel off and speaker unplugged you can ID the cause and fix. All you need is a magnetic philips screwdriver for job. Remove screw Located in front seatbelt cavity, flash light helps to ID, then pull panel up first and then towards you. Don't pull too far, unplug speaker. Tap on it to ID rattle cause.
Old 07-19-2011 | 03:17 PM
mm450exc's Avatar
It's the smaller(top) section of grill that vibrates. If I hold it the vibration stops. How is this fixed? Do I really have to remove the entire panel?
Old 07-19-2011 | 04:20 PM
gmoney's Avatar
yep, its easy though.
Old 07-19-2011 | 09:52 PM
lexart's Avatar
lexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond repute
The buzz is fixed fairly easy by placing adhesive felt strips on the inside of the '1' shaped hooks used to secure the grill to the speaker. You can see the six '1' hooks in the picture above . . .
Cut felt strips long enough to cover the inside of '1' and wrap over the top to the other side. When all six posts are covered with felt, pop the speaker grill back in - no more buzz
Old 07-20-2011 | 08:14 AM
nyamg's Avatar
nyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud of
same problem here....it drives me insane.
Old 07-20-2011 | 01:58 PM
mm450exc's Avatar
PV=nRT.
09-09-2022 06:06 PM
markj
911
04-07-2016 05:44 PM
Yellopeter
Cayenne
10-09-2015 11:20 AM
Rockinc1
09-30-2015 06:44 PM
Quick Reply: Speaker grill cover vibration
