Exhaust tone changes with Sport ON?
No skand but i will check at home tonight and get back to you. I did the test today at the office parked outside under the awning. There was also some noise from passing traffic on the main road. At home i am in a fully enclosed garage so that will be ultimate test.
You may have noticed your exhaust tone changing when you start up:
https://www.6speedonline.com/forums/...8&d=1308284571
Sport mode changes several parameters that will influence the tone of the exhaust. If you have a 997TT with a LWFW, listen to the rattle when the engine is warmed up with and without sport mode. Huge difference.
I have a cab and FVD exhaust and with the top down, I swear that when cruising at 40-50mph in 3rd or 4th (low rpm), when I turn sport on and off I can hear a difference! (I think).
Skand i checked it again in the closed garage and to be honest there is indeed a small difference to the ears but really nothing to get too excited about. It probably sounds more noticeable at WOT....but i cant be the driver and stand on the footpath at same time to check.
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
