Michelin Super Sport vs. P. Corsa & the importance of tire's sidewall stiffness.
#46
AMG: The CS is a great platform. I tracked a 2nd gen car for 2 years and enjoyed it. Only problem is that is is hugely underpowered. If you're seriously considering one for track, you'd probably be better off starting with a 2nd gen car as they have resolved two serious track related failure issues: oil starvation at high G's and power steering overheating. The gen 2 CS is solid out of the box, only problem will be finding one to your liking as their numbers are lower. I've never tracked a turbo but I would imagine a properly track prepped car would be immensely satisfying to drive on track vs. a CS.
If the thought of balling up the turbo gives you pause, have you ever considered track insurance? Good piece of mind.
Will report back my thoughts on the cayman track car i'll be in on monday. just checked porsche's website. Posted weight for the cayman is 2,976 lbs. wow, that's pretty light. the turbo is what, 3,500? that's a huge difference - and that's before i rip out the interior and shed some more pounds! LOL.
#48
For better traction, also don't use too much negative camber - IOW use stock toe and camber settings. Note that alignment setting for best straight line traction and max speed (less neg. camber, less toe) is not the same as what's best for the track and carving curves (more negative camber, some toe in or even slight toe out if you want to be adventurous).
R compound Michelin Cup: front/rear 20/27 = 47 lbs
R comp Pirelli Corsa: 21/26 = 47
Michelin Pilot Super Sport: 25/30 = 55
#49
I agree with ChrisEVO that a major problem with Cayman/Boxster, in particular for us Turbo owners, is the lack of power. This car is much better on tight canyon roads, where speed is limited, than on big long tracks. You simply have to keep the engine at 5000+ and even then it still feels like it has no power.
I forgot to mention the avoidance test to check out the chassis dynamics: 50 mph empty road, quick left then quick right with the steering. Do this to both cars and you'll see what a problem the rear engine is. With the Cayman, it is one quick simple change, with the Turbo after that quick right you'll see the rear continues to swing left!
But looking beyond the power problem and the jittery ride, the Cayman/Boxster is so pure and a dream to drive: fast turn-in, fast steering, clean motion, feel so so so very safe at the limit. It has replaced the GT3 as my secret dream second Porsche.
#50
Trofeos
Not sure if anyone has chimed in but the trofeo sidewalls are the stiffest I have ever experienced. One word of warning is the tire pressure variation from cold to hot. Be careful and check it once warmed up. The increase is in the neighborhood of 15-20%. However, once "reset" they maintain contant pressure as long as they maintain temp. They are also surprisingly quiet.
#51
It appears you are trying out a lot of different tires (what have you tried lately?)? Please post your comparisons as "comparative analysis" LOL is the most helpful type of reviews. 2 major parameters that people would be interested in, not just "traction":
1. sidewall stiffness (good ol' handling versus ride comfort trade-off) and
2. road noise.
COBB Tuning
11-09-2015 08:02 PM
L.A.P.
10-19-2015 10:01 PM
L.A.P.
08-23-2015 11:48 PM
Sterlingc1975
08-22-2015 02:30 PM
