More Power coming out of 1-2 manual shift
With normal aspirated engines, the shifting is simple, with foot on clutch and off gas, engine revs come down as the shift occurs.
With my turbo, this causes tremendous hesitation when revs drop as does turbo rev-power, then it takes time for turbos to get back up to speed. Not fast like engine revs.
I notice with PDK, the on/off/on of turbo revs doesn't occur making shifts fast and furious without hesitation.
I found when I shift and hold some gas pedal, the power coming out the 1-2 shift is tremendous with no hesitation. Takes some practice to get it right. In fact it is so fast, that I get some straight line acceleration slippage that I hope is coming from rear tires having 11-12K miles. I mean no hesitation and the car really flies without any drive line clunking noise occurring.
I just hope this process is not damaging the clutch and what I feel is not clutch slippage. Sure easier on the drive line, but may be too much force on the clutch....any thoughts out there on this??
With pdk or tiptronic there is no need to release the throttle during gearshift. With a manual, between each shift the boost is momentarily lost and therefore must recover upon the next shift and re application of the throttle. A naturally aspirated engine is just not as noticeable. As with any turbo the PDK and tip will always maintain acceleration between shifts better than any manual (turbo or atmo) will.
Keeping your foot on the gas while shifting means u are likely power shifting to some degree.
Doing this regularly will eat away at your clutch.
If u want to try and hit boost quicker after shifting, try shifting higher in the rpm range.
That is the point I was trying to make is that if you keep some gas going and not remove foot completely from gas pedal, then when you shift, the turbos are still spooling a bit and that hesitation from normal-like shift is gone. Really works great for improved acceleration, but I worry about danger to stock clutch.
In a manual if you are upshifting you are meant to remove your foot from the accelerater pedal when changing gear (from say second to third and so on) or the engine will rev up uncontrollably, so when you re engage the clutch it's going to burn if the engine is revving out of synch with the speed of the gear. Downshifting is a different story as you can speed match the gear by using heel toe technique. It's really only when the horsepower and torque is increased that there is a need to update the clamping pressure of the clutch.
In a manual transmission turbo car, if you powershift do you stay in boost between gears or does it drop with the clutch disengagement?
I know powershifting isn't great for your clutch or drivetrain. Just curious about trying to maximize the acceleration.
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
