Protomotive 983whp/963tq Stock Motor
#91
If it's not misfiring, it's dissipating heat properly, and the A/Fs look good, I don't see why it should be a problem in theory. That said, I'm with you in thinking it just doesn't seem safe. Oh man, this is just the coolest thing ever. Congrats.
#93
It does burn cooler but you're putting 30% more fuel mass across the turbine.
#94
30% is the fuel trim adjustment for the stoichiometry. It's more like 15% greater combustion mass if you go through the calcs but you have the right idea.
#95
Also E85 requires around 40% more fuel flow, that's why you need bigger injectors.
#97
Would love to see a dyno graph showing the spool difference between the .63 A/R and the .82 A/R
#99
I just checked my emails and I have one from Jake who specifically stated there is only one option for the turbine housing. Maybe some people can get custom set-ups but mine is pretty much standard. It's less expensive that way.
#100
it's around 300 rpm's and 82 picks up 20 more hp on top.
#102
I don't think so actually. I've never heard of a turbo that only comes with one option for the turbine housing maybe I'm wrong though.
#104
Alpha 3076 has two turbine housing option;
1- Tial turbine housing with internal wastegate (this doesnt have any other AR option)
2- Regular Garrett T3 flanged turbine housing with external wastegate
(you can get 0.63 or 0.82 a/r with this housing)
besiktas's a3076 turbos have Garrett turbine housings at the back so he had tried 0.63 and 0.82 on them.
I hope this will clarify the A/R subject
ESMOTOR
Home of the Worlds quickest Porsches
1/4 mile: 7,95 @ 190 mph
100-200km/h: 2.16 sec
200-300km/h: 3.43 sec
60-130mph: 2.52 sec
100-150mph: 2.19 sec
Email: emre@esmotor.com.tr
Web: http://www.esmotor.com.tr
Instagram: http://www.instagram.com/esmotor
ESMOTOR
60-130mph: 2.52 sec
#105
