Protomotive 983whp/963tq Stock Motor
#123
I am getting used to it actually. I do not think I have the conversion as it is very easy to depress.
#125
Thanks!
#128
Proto uses Pauter so I figured my tuner knows best. Actually, I considered several brands but Pauter is local to me. I'm sure Carillo makes a nice rod too but there have been discussions about shaving down the oil pump to fit the rods and that's not something I want to get into.
I weighed all rods and the specs on these beauties are tight. All were within +/-0.5g of 535.0g (including bolts). These are a nice set of rods.
Not yet but will do after the motor upgrade.
#129
Fair enough but I would have tested it to make sure the power you were running wasnt just dyno HP if you know what I mean!
#130
Power should be similar before and after the motor upgrade--just reinforced to better handle the power.
#131
Ahh okay well good luck.
I Look forward to when it's finished as it will be amazing.
#133
Big fan of Pauter Rods... went through several motors on my Audi S4 .. blocks .. pistons heads.. been using the same set of Pauter Rods since the beginning. Car made 720 AWHP on Dyno Dynamics.. 860 AWHP on DynoJet
#135
Great job! With stock engine ... ? Fine! Only 3076, 044er, exhaust, software, and ... ? 983whp/963tq with E85 ... Great. What parts you changed too ? How boost ? Tip or 6M ? Any 60-130 (better 100-200 an 200-300 times?) ?
