Sneak peak of my new coolers!
#61
Here's some result I have lots of logs but I though I would just post the result's that mean something.
Test has been done on the same day within the space of 5hrs
Stock coolers.
<OEngine speed/ Intake Temp/Ambient temp/Vehicle speed
6226.5 / 44c / 11.3c / 237.4kmh
<OAerospace coolers.
<OEngine speed/ Intake Temp/Ambient temp/Vehicle speed<O</O
6377.5 / 29c / 13.5c / 237.4kmh
<O6476.5 / 37c / 14.3c / 300.24kmh<O</O
Stock coolers.
#62
I'm running stock turbo's, with FVD re-map and other mods.
Heres a screen shot.
I do have a log of before and after taken from durametrics.
#63
Really great thread...Well done...
as a comment i would like to add that i just read your thread and really liked what you did...excellent job...On your first page i thought you would use oem plastic and tanks with your core...did you ever thought of that?you could have lowered iat even more...
But even with alu end tanks you managed to lower iat as gt2rs ics Vs 997,1 ics...and this shows you used excellent core...
#64
The cores I have are the very best out there!
There is no better!
#68
Im sure these are the very best available...that being said I just ordered the 997.2 coolers..I think those will suffice for my street use and your coolers will be for the very hard core highest hp cars...lets say over 650 hp. I can only assume with all the work, testing and research these will have to sell well above the $990 i just paid for the 997.2 coolers. Good luck but its almost like spinning your wheels due to the availability of the super cheap and effective 997.2 coolers...can you sell enough of these to make it worth your while? I hope you do based on your hard work and efforts.
#70
#73
#74
i am almost sure your core is better than GT2RS core (even though thermal efficiency of it is great) I wonder how would it be to combine gt2rs end tanks with your core...To take advantage of plastic end tanks...
On the other hand it would be awesome to have a test car with your IC at left side and GT2RS ic on right side...Up to my knowledge that would be the toughest test to pass...Once again bravo for your work...you manage to compete the most thermal efficient ic...
#75
Thankyou bro I hope they are the most thermal efficient IC but I still have alot of testing to do epsecially when the warmer weather kicks in next year.
I think it would be good to test them against the GT2RS coolers but I think we both know what the outcome will be if we go by your logs!!
