Motor Upgrade Begins
[quote=jhbrennan;3414676]
Good stuff Dave. What happened with your crankcase?https://www.6speedonline.com/forums/...ggestions.html
Excellent points Joe. Unfortunately, not in the budget right now. Is the GT3 rs crank journals the same size as 997t? I've been debating on the 12 mm studs, however. My heads could already be lifting a little at high boost with stock studs which one reason I'm doing this upgrade. Todd tuned this thing to the max. Hopefully my upgrade will hold the power and I'll be able to enjoy this set-up for a while. Thanks for your advice.
Hi Dave, looks good but am i reading it right you're not changing pistons and so on? I mean you'll be removing those to change the rods anyway so it goes without saying you'll be changing the rings right? And pulling the engine apart and putting it back together is the main expense here. It's just seems an opportunity too good to miss really as having to back over that same old ground again at a later point only means the same parts you are changing now will be getting changed again in that process....meaning more expense again. Same goes with porting the heads. I assume you'll be removing the valves...a quick relapp, new stem seals and so on. Do it once do it right i say .
While I'm not in Dave's shoes, I think once you start blueprinting an engine build, you could go absolutely crazy with every internal upgrade that makes a major dent in your budget. If I'm reading him correctly and based on a few emails, I think he's got a good idea where he wants to be in terms of horsepower, and the build he is committing to should keep him safe at that level.
Hear what you say bob. It can sure add up indeed. Always interested to hear the details of the build list (new parts and any reconditioning work to the core parts) though. So Dave give me gory details....i promise not to be too critical
TTdude I like where this is going. That setup should be pretty stout to hold your e85-3076 setup probably pegging those turbos to the max making close to 1k whp! Being that Proto tuned your car to 983whp the first time and also considering that 3076 tial turbo is rated to 495whp (per turbo) that should have you flying down any track/ course that you find your self at. Awesome setup for your power limits that you currently have... Once you switch to an externally gated 35xx garret turbo is when your start wishing you had done the high rate valve springs, gt3 crank, forged rings, 12mm studs and whatever they can tweak... But I think it was you that once said that building a motor like that is just a way to chase down some more variables that can go wrong... soon enough you'll be back in business and and have no regrets for the power you seek.
Cheers
Cheers
Cheers
Cheers
Although unrelated to upgrades for power, have you considered doing your coolant pipes while the engine is out? Relatively cheap insurance for a well known problem, even on stock cars. Really wish I did mine when my engine was out getting this fixed.
Some good suggestions here (especially the coolant pipes). But this is the "slippery slope" I was worried about...12mm studs (I presume that is diameter and that you have to bore out the original 10mm hole?), updated crankshaft (and why would the GT3RS crankshaft be stronger than the one on the turbo????), etc...
