More power on VTG
More power on VTG
Hallo. I have tiprtonic car, with swizter intercoolers and y-pipe,swizter modified VTG turbos, EvoTech exhaust headers, stock muff with out cats, modified tiptronic! Proto tune and Proto TCU soft!
Now I want get more power, but I don't want change VTG on garret! Some idea, what I need change for get more power? Maybe I need change swizter VTG for another?! Or change stock muff?! Or anything more?!)). Thank you
Forget the VTG's, they are too susceptible to heat related issues causing the VTG mechanism to malfunction. If you want big tiptronic power, you know exactly what to do, the R911 package.
https://www.6speedonline.com/forums/...-test-run.html
Im in a setup similar to yours... 65mm VTGs with all the bolt-ons, along with a built motor and upgraded trans internals as well. I have a tune for 93 octane and 100 octane... The car is a total different animal with the good gas. Before I switch to my GT30setup ill try to get some numbers with my VTGs pegged to the max with some big injectors... my guess will be around 640-650WHP depending on dyno of course. Since I daily drive my car often and hard nonetheless; I'm thinking of using champions 68mm kit
