Power potential of a 997.1TT with bolt on parts...
#31
Hello Gents... I am wondering what a 997.1TT is capable of with bolt on parts without changing the turbos or any involving modifications.
For instance, I am looking for what can this car do with the following parts:
- Exhaust
- Tune
- Headers
- Intake
- Other minor things that can increase the power potential without breaking the bank.
Please pardon me if this topic has been discussed many many times before ... I searched and didn't come across the information I am looking for.
Thank you much in advance for your information.
- Exhaust
- Tune
- Headers
- Intake
#32
And if there is another kit making 700/750 and running 10.80@133mph for 18k, please let me know who, im sure there are, i just want to see it. That Switzer exhaust is really something to look at, and i think the nicest exhaust out there. I have an R911 and i still think about that yellow vgt700, i loved that thing, was like a bike.
#33
- Exhaust
- Tune
- Headers
- Intake
- Exhaust
- Tune
- Headers
- Intake
I see you are from NY. Our company is located two hours south of NYC.
We are full service late model Porsche tuner focusing on the Turbo models. We have a Mustang Chassis Dyno, onsite Fabrication, install capability, and a direct line to GIAC for software needs. Anything you have read in this thread, we can do. From wheels spacers all the way up to 750hp turbo kits.
If you don't mind, shoot me an email with your phone number. I would like to call and discuss our services.
Mike@AWE-Tuning.com
I look forward to hearing from you.
#34
I went with the EVOMS 580 tune when she had 16K on the clock. The clutch was fine pre-tune but post tune it slipped almost immediately especially in 3rd. Had the Sachs put in. The original taken out had at least 60% life left so not a worn clutch issue but just can't hold the power. The car as Gene said is so drivable if you want to drive slow she is happy to oblige and easy as pie but hit the loud pedal and its like a totally different car
#35
What kind of boost does the stock VTG's need to pull 600awhp
A custom live ECU mapping and a top notch turbo-back exhaust (with free flowing sport cats) won't give you more than 100hp over stock. So i doubt that by adding bigger ic's, silicone hoses, headers, exhaust tips and recirculation diverter valves will increase another 100hp, in a total of +200hp over stock. Tuners marketing isn't always a fair game.
I am pretty sure that some of the tuners have developed kits involving what you have layed out above but also opening up the intake side of the motor - throttle body, y pipe, plenum - to achieve close to 600 whp. I have not kept up with the latest goodies from all of the tuners but I do know that people were in the ballpark of 580+whp without changing the turbos. Granted dyno numbers are tricky to compare as an absolute value across the board but the unlocking the intake side "stage III" did add ~40+whp to the "stage II" cars
From there, intercoolers, y-pipes, larger TB and plenum will yield nominal increases in power and definite improvements in consistency, but nothing close to 600 at the wheels, I just don't think that's possible.
Our 65mm Billet VTG's, which are probably the largest flowing 65mm VTG's out there, will yield 600 at the wheels on pump gas, a little more on race fuel. To get that without turbos is just not possible. The stock turbos just can't possibly flow that much.
#36
I have to agree with Tiago on this one Lou. In our experience, a stock 480 Crank HP turbo will put down about 420-430 at the wheels, depending on the type of dyno used. With a good exhaust system and ECU flash, you would see approximately 70-80 hp at the wheels increase, which puts you around 500 at the wheels.
I sincerely appropriate posts like yours ,Thanks
#37
we have two vgt cars that run very low 6s . 60 to 130 . And make 590 to 600 4wheel hp on a mainline dyno.Both tuned by proto . Both have stock y pipes and tb s. and one eveN has stock intercoolers . Sometimes less is more
#38
Are those cars running stock VTG's or upgraded? With all due respect, to get even close to that HP on stock turbos, and especially with stock intercoolers, is risking serious damage to the hardware on those two cars.
#39
All due respect to those running said setups, but the less is more philosophy has been known to cause issues. Pushing stock hardware into a region of inefficiency can cause serious issues.
#40
Both cars have modded turbos . and run e85 . We have gone over data logs with todd and are very pleased with results .
#41
I thought we were talking stock turbos that's why I was like "whoa!"...haha
#42
LOL this place has been boring . Had to add a lil excitement . PS thank you for advice on springs . They work great
#43
Can u elaborate on that Neil - what du mean by stock hardwear and what r the issues.
#44
Can 997s have a 93 map and E85 map?
#45
With vgts you can get away with just changing injectors . the stock pumps run out a lil over 600 whp on e85 . whats on your mind joe lol
