New Porsche 997.2 Turbo S Project Car - Full Build Thread
Old 03-01-2012 | 02:21 PM
Weebs's Avatar
Weebs has much to be proud ofWeebs has much to be proud ofWeebs has much to be proud ofWeebs has much to be proud ofWeebs has much to be proud ofWeebs has much to be proud ofWeebs has much to be proud ofWeebs has much to be proud ofWeebs has much to be proud ofWeebs has much to be proud of
That custom wheel is a GREAT idea. I looked for this option on your website but couldn't find it. Did I miss it? If not, can you send me a PM with pricing? Carrera Red... of course.
  #32
Old 03-01-2012 | 02:31 PM
vividracing's Avatar
Nope did not miss it Just busy and have not added it. Will do tomorrow. Here is a gallery of a bunch of different wheels including more PDK pics. Will send a PM to discuss - http://www.vividracing.com/blog/gall...21&gallery=573
  #33
Old 03-02-2012 | 12:24 PM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
Originally Posted by vividracing
Thank you! Next up is aero kit, wheels, suspension, then back into power
Time to start multi-tasking, you can remove the engine, wheels and bumpers at the same time.
  #34
Old 03-02-2012 | 12:26 PM
LOL. See I have this problem here that gets in the way of my own cars... its called a shop!
  #35
Old 03-03-2012 | 08:35 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
I am not sure I understand why sport mode yields less power. Isn't just a more sensitive throttle? Should I drive in regular mode for better performance?
  #36
Old 03-03-2012 | 10:30 AM
FadeToBlack's Avatar
FadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of light
Maybe stock cars perform differently.
  #37
Old 03-04-2012 | 10:56 AM
Miguel-H's Avatar
Miguel-H is infamous around these parts
Subscribed. I like me a good project.
  #38
Old 03-04-2012 | 12:47 PM
T.Hill's Avatar
T.Hill is a jewel in the roughT.Hill is a jewel in the roughT.Hill is a jewel in the roughT.Hill is a jewel in the rough
^ Agreed. Should be good!
  #39
Old 03-04-2012 | 02:50 PM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
Subscribed.
  #40
Old 03-05-2012 | 09:29 AM
Sport Mode gives you extra boost for X amount of seconds as well as better throttle response. However since Sport is based off EGT temps, the car will start to pull timing and make the car slower if you continually run it this way. So you can see by the HP curve you still get that initial boost blast, but then taper off. For 0-60 sport is probably better, but for 60-130 standard is better. The nice thing about ECU Flash is we give you the extra boost and throttle response in standard mode like sport.
  #41
Old 03-05-2012 | 10:23 AM
fattyk's Avatar
fattyk is infamous around these parts
will a softronic tune TT be as powerful as a softronic tune TTS?
  #42
Old 03-05-2012 | 10:28 AM
both at 615bhp. So yes.
  #43
Old 03-05-2012 | 10:32 AM
fattyk's Avatar
since I'm planning to softronic tune my PDK turbo, there isn't a need to pay a premium price for a TTS.
i'm still deciding whether to get a PDK turbo or TTS.
because TTS stock is rated @530hp n TT only @500hp.
what about torque? TTS @700nm n TT only @650nm
so it is true that a softronic tune TT will be as powerful as a softronic tune TTS?
  #44
Old 03-05-2012 | 10:36 AM
Choosing which car to buy is hard for me to give you advice as much of it comes down to options. The HP and TQ changes are the same for both.
  #45
Old 03-14-2012 | 05:48 PM
Just finished a SLEW of mods and will be updating our Project Car section here - http://www.vividracing.com/blog/category/project-cars/project-997-2tt/
We did just get our new custom PDK Sport Design steering wheel by Agency Power installed.
The install process is pretty straight forward except getting the silver Y-Trim off is a royal pain and requires almost breaking it.
To uninstall the PDK steering wheel, did some Google searching and what was out there sucked. So hopefully this helps. Basically to get the wheel off, you need some flat tab pullers or skinny flat head screwdrivers to put in between the column and wheel and popout the latch mechanism that holds the airbag in place. Remember to first disconnect your battery! Once that is done unplug the airbag and you will need to remove the nut that holds the wheel to the spline. Good luck!
here is the wheel removed with the Y-Trim popped
See the left side that white tab, that is the *****. There is glue that holds the Y-Trim together kinda like headlight.
Here is how the paddle is removed and then reinstalled
We put tape on the bottom to not scratch the trim piece
Tighten wheel in place and make sure it is straight. Then push the Y-Trim on!
You likey? Now go buy one here - http://www.vividracing.com/catalog/search/agency+steering%20wheel.html
