Sponsored by: Bears Transport
AWD dyno
Old 02-12-2012, 06:20 AM
MKS's Avatar
MKS
MKS is offline
MKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of light
AWD dyno
What's the best dyno for a 997 turbo?
Old 02-12-2012, 07:39 AM
MKS's Avatar
MKS
MKS is offline
Is dynojet bad for the car?
Old 02-12-2012, 10:07 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
AWD is best else you will have to remove the front drive-shaft to use RWD dyno.
Old 02-12-2012, 11:37 AM
MKS's Avatar
MKS
MKS is offline
I will use an awd dyno but which one is better for the 997tt
Old 02-12-2012, 01:57 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Not sure what you mean by better. You essentially have two choices, Mustang as AWD dyno and Dynojet which requires the removal of front-drive shaft. Be aware that the Dynojet will read a little higher on the hp.
However, Dyno numbers are really only good as a comparative check regarding the before and after mods as there are way too many variables to truly check numbers across, cars, dynos, temperatures and etc.
There are many threads on that topic.
Old 02-12-2012, 02:05 PM
FLT6SPD's Avatar
FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !
Which ever dyno you choose the front and rear pods/drums must be mechanically connected.
As 512bb mentioned search is your friend.
Old 02-13-2012, 06:20 AM
FadeToBlack's Avatar
FadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of light
Maha is a great dyno. Mustang too. Dynojet is... you know.
Old 02-13-2012, 11:26 AM
Jake's Oy's Avatar
Jake's Oy is infamous around these partsJake's Oy is infamous around these parts
Someone else asked the same question a while ago, this is the info I came up with.
https://www.6speedonline.com/forums/...ml#post3333769
Old 02-14-2012, 05:12 AM
MKS's Avatar
MKS
MKS is offline
Still no exact answer i guess it's better to ask the GTR guys!
Old 02-14-2012, 09:54 AM
512bb's Avatar
Let us know what they say.
Old 02-15-2012, 04:34 AM
MKS's Avatar
MKS
MKS is offline
[QUOTE=512bb;3456064]Let us know what they
Most big tuners are using the mustang awd dyno so I'll look for one
Old 02-15-2012, 04:21 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Bro , to be honest , you should dyno your car with a dyno that have a connecter between the 2 rollers , because if you run the dyno the tires will slip and the car will not move ! Or you should do what i did before to switch to RWD mode
The big issue is there are no dyno have special fans to put toward the ICs , as you know your Intake filter is there ..
My advise to you , take the vbox and see what your car can do 100-200 , 60-130 , 100-150 .. Compare it with guys here !
Good luck mohmd
Old 02-16-2012, 07:03 AM
Mitch@AMS's Avatar
Mitch@AMS is infamous around these parts
The rollers do need to be linked or the AWD system will be unhappy.
That being said you can use a Dynojet as long as the rollers are linked. Not all Dyno Jets are linked it is an option to get from DJ so be sure to ask whatever shop has the dyno. Or you can use a Mustang as they are all linked, as far as I know.
Hope that helps.
Mitch
Old 02-16-2012, 09:17 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
another option is Dyno Dynamics which is an australian manufactured dyno.
Old 02-16-2012, 09:19 AM
Carbon's Avatar
Carbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond repute
2nd the MAHA. I'm told there are very few shops that have these here.
Quick Reply: AWD dyno
