GT-R guy wanting a 997 turbo
#62
BUT - I don't think there are any more facelifts for the R35, the new version has been shown, to be released in a few months (with the GT-R nismo coming around the Summer of '14). We'll see where the R36 goes. Apparently there was a problem fitting the hybrid system (from Williams) into the R35 (AWD getting in the way). I think the R36 is being designed from the ground up to accommodate the hybrid power plant. We'll see.
With the R35 nismo doing 7:08, it is somewhat conceivable that perhaps a hybrid GT-R nismo (like the 918, P1, La Ferrari, etc...) may yield a time under 7 minutes... Would be pretty cool.
#63
But my 997tt is actually fun to drive. To be honest, I think a C2S with PSE and 6sp is even more fun than the turbo for everyday driving….
#64
I've stated many times in the past - I have just as much fun tracking a /92 Miata, as I do a 997GT3.
It all depends on what your preference is, and what you're trying to accomplish in a given situation.
#65
Interesting read. I'm currently thinking about going from a 997.1TT to a GT-R, most likely a 2015 since it sounds like they improved the suspension further for a more compliant ride without sacrificing performance.
#66
Being blunt here: if you buy a 2015 gtr, you are a SUCKER. The new model is right around the corner, why pay an elevated price for something that will be "old news" in very short order. Buy a gently used 2013 (or hell 2014, but I wouldn't go this new) and upgrade the suspension if it's that big of a deal to you. I had a gtr (2011) and the suspension differences that were the biggest/most noticeable were implemented AFTER the 2011 MY. After that point it's just slight tweaks here and there. Not worth the huge markup
#67
#68
Just get rid of the RFTs and the ride is transformed.
Bish
#69
This is 100% accurate. PSS's etc... will make the ride a LOT more compliant.
I've stayed with RFT's for two (primary) reasons:
#1 I prefer the stiffer sidewall when tracking (preference, based on zero factual data)
#2 I had a flat tire on the way to work a month ago - drove home, bought tire online, drove to the shop, replaced tire. No drama.
#70
I've never seen the data but on a road course I'd wager good money that a set of PSS's would be only slightly slower than the OEM RFT's; hence for a DD that is only driven a few times a year at a DE event, the advantages of the PSS's far out way the RFTs. BUT, if you're really getting on the car at the track the RFT's need to be removed and a decent 'R' compound tyre used; that's what a dedicated track wheel/tyre setup is for.
Re: getting a flat. The OEM RFTs are not designed to be continuously driven when they are punctured, in fact there is a finite number of miles beyond which the tyre has to be replaced if driven whilst flat. It is designed to be much safer when you receive a puncture so that you can (more) safely pull over to the side of the road and/or get off the road until you can have the RFT patched AND plugged (which the correct way to fix a puncture in an RFT). When I had the GT-R I had Pirelli P-Zeros on the car; (PSS's weren't available back then), and carried a can of 'fix-a-flat' with me.
Bish
#71
Let's see where they price the NISMO, but I'm assuming that it's going to be pretty ridiculous seeing the considerable price they've put on parts for the GTR.
#72
Just a couple of points:
Bish
Bish
Re: Flat - The fact that my work is less than 10 miles away from home, and the Nissan dealership is 3 miles away, my experience was easy.
But I agree that the price may be outside what I'm willing to pay for one. I'm hoping it is under $150k (if it is $125k or less, I'll be on my way down to order one in either white, or that matte gray that people are hating on, exclusive to the NISMO). But based on those parts that we saw in the past, I'm not putting too much stock in my optimism.
#73
I imagine that the Nismo will be staggeringly expensive, and frankly will only be slightly faster on most road courses; (remember the N'ring is 14 miles long whereas the vast majority of tracks are between 2-4 miles in length, hence not enough length for its advantages to really shine), plus I bet it will be a real bear to try and DD.
I had my name down at Boulder Nissan to potentially order a 2015 as the car was reported to have an updated interior; 7 speed DCT, etc, but since there are only incremental changes versus the 2014, I'll wait to see what the R36 is like. In the meantime either the Jag F type V8 R Coupe or 2015 Vette Z0? will probably get my money.
Bish
Bish
#74
I agree with all of this.
I think we (prospective buyers) are all waiting for this. The fact that production is limited to 200/yr may lessen my chances if I wait too long.
#75
$125k would be fantastic, but my guess will be that it'll be north of $150k if it's anything like the R34 end of model life cycle special edition. With the additional work they've done to the chassis and engine, I could see it being like the GT3RS 4.0s that go for well above MSRP in the used market.
PelicanParts.com
997 Turbo Vendor Classifieds
08-20-2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
PelicanParts.com
08-18-2015 03:42 PM
PelicanParts.com
08-18-2015 03:41 PM
