EVOMS Billet diverter valves - thoughts?
Old 02-16-2012 | 02:41 AM
mozhacker's Avatar
mozhacker is infamous around these parts
First question - is there anyone who has these that can offer before and after take? Conceptually I get the point - but can you feel it? And if so, any cons or negatives?
Researched few threads and some were positive but one on another board claimed the valves somehow changed mid range or partial throttle for the negative because it was stiffer?
Context is I'm getting sharkwerks exhaust and evomsit 565 ecu upgrade installed and debating this additional mod.
Old 02-16-2012 | 02:52 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
well i used forge , AP
both were fine and never fail
Old 02-16-2012 | 03:06 AM
mozhacker's Avatar
Did you feel any difference between stock and your forge ones?
Old 02-16-2012 | 03:49 AM
ysfg35's Avatar
well , i installed the upgraded valves because i was afraid from the stock valves to failed
you will notice a woosh sound after letting the gas pedal and it hold boost well
Old 02-16-2012 | 04:14 AM
Turbo Fanatic's Avatar
I have a set of Forge? Diverters I will sell you for $125 shipped. Just need them out of here. I can send you pics. I'm 95% sure they are forge brand.
Sorry these were on a 996T. Probably the same part but please verify.
Old 02-19-2012 | 12:59 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
996tt DV's are not the same design as the 997TT DV's.
They won't work on a 997TT.
Old 02-19-2012 | 01:09 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Well in terms of a big difference no.
All it will do for you is never break and handle higher boost levels as it comes with different springs for different boost levels, so it is good for peace of mind.
AP, Forge, Evoms all the same if you ask me!
Just pick the set that is not over priced.
I use the Forge on my car.
Old 02-19-2012 | 04:02 PM
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
Forge here.
Old 02-20-2012 | 07:21 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I had issues with one set of early aftermarket diverters where the O-rings melted then leaked. I think the later O-rings were upgraded, but I decided to go back to stock
Old 02-20-2012 | 11:18 AM
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
It can be just a wrong impression but during the 2.5 years of following the 997TT aftermarket progress i have the impression that aftermarket diverter valves is more a US tuners sell marketing because the Euro tuners don't show that must need upgrade. I'm not saying that isn't a improvement over stock, just that the benefit/cost is minimal. Same when adding ic's silicone hoses when still using stock boost or just with a ecu tune, or aftermarket headers with stock or even modified VTG's.
Old 02-20-2012 | 03:13 PM
BaldBag's Avatar
BaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant future
Im with tiago, I think these are a waste of money to consider as an upgrade if yours are not broken.
PV=nRT.
09-09-2022 07:06 PM
XLR82XS
10-05-2015 08:02 AM
shifter_
09-08-2015 01:07 PM
ECS Tuning - VW
09-02-2015 02:19 PM
Quick Reply: EVOMS Billet diverter valves - thoughts?
