Europipe exhaust question
I am going to add an aftermarket exhaust soon to my 2012 997.2 Turbo. I like the Europipe sound. I have a question about installation. My current exhaust does open up when the sport button is engaged. Will the Europipe also work the same way? Are there any special installation considerations or instruction? I have listened to several online videos.....Is this system much louder than stock?Thanks
The increase in volume when in Sport mode is a function of the engine, not the exhaust, so nothing changes in the exhaust.
I installed my EP last year. The instructions and special tools which EP supplies are all you need in addition to standard metric wrenches and sockets. I recommend having a helper when you R&R the rear bumper, if you' ve never done it before. Not heavy, but awkward. The hardest part was unclipping and snaking through the wiring for the O2 sensors. If you have some miles on your car, the nuts/studs at the turbos may be corroded and should be soaked with penetrating oil to prevent them from galling or breaking off. Steff supplies new studs, nuts and gaskets in his kit.
The system isn't much louder than stock at idle and mild acceleration, just deeper and throatier sound. It is much louder at wider throttle opening, but not obnoxious. No droning at highway speeds. Faster throttle response and turbo spool up..
The product quality and support from Stef are second to none.
I posted pictures of my install on the site last year. If you need more, PM me and I can email you pictures.
Good luck!
Good luck!
A big plus ONE for AIRMITCH.
I ordered and had my dealer install Stef's Europipe in December.
First they said the quality was the best they had ever seen. It fit perfectly.
Second. it took the dealer four hours to install and cost me $700. The first quote was the flat rate charge of $1,200 and I told them to "Re do the pricing" we agreed on the $700.
Third. No warranty problem at all.
Fourth. the sound is just as mentioned in the other posts. For me it is Perfect. no drone etc...
One of the dealer's other customers wanted a new exhaust for his turbo, and he purchased three different after market brands, had each installed, drove them, removed them. and once the Europipe was installed it stayed on the car. It is the best.
Second start will override cold start procedure and eliminate these sounds...You cant go wrong with Stef and Europipe...His products are Better quality than OE and they last in time...they dont fail after one or two years...I ve changed 4 different exhausts (all of them with good sound and performance)but stayed with the exceptional build quality of europipe...
10-06-2015 03:43 PM
turbotuner20v
09-11-2015 12:02 PM
