Dectane tailights problem
Old 03-03-2012 | 10:36 AM
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
I have concluded my due diligence with this, and I will not be going ahead, for a few reasons.
Perone is correct in the wires he has selected. They are the ones that take voltage when the proper buttons are pushed. The green/white is the fog and the green orange is the brake.
The fog light when turned on is VERY bright. The dectane light has a dual row of leds as the outline of the triangle. By design, when the fog is illuminated, the few leds at the top and bottom become single row, so as not to be too much.
This mechanism which is achieved with two wires i believe, seems to complicated for my plain electrician skills.
Also, as I do agree that the brake looks a bit awkward with that inverse C design, I have turned on the Daytime Running Lights function from my PCM, and as a result the outline of the lights is always on, reducing the effect of the pattern of the brake light.
Below are visual aids which describe this whole situation.
BRAKE ONLY
BRAKE WITH LIGHTS ON
BRAKE WITH LIGHTS ON AND FOG LIGHT. Notice how the second row of lights in the middle goes out, leaving a single light. Perone, perhaps you are mistaken that the middle lights come off? Perhaps its only one row that does?
That Fog light is way too bright for braking...
  #32
Old 03-03-2012 | 11:07 AM
jhbrennan's Avatar
Thanks for all your research...but I could never understand all the concern. Who cares what the guy following you sees?
  #33
Old 03-03-2012 | 11:29 AM
dianic's Avatar
Ha! What a great point! I guess we are all a bit twisted.
For the same reason why do I care if I have dual or single tips? Hmmm...
Certainly puts a few things in perspective. As always, good post!
  #34
Old 03-03-2012 | 11:39 AM
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
Great work Nick and thanks for the effort.
Now, let's see some picture of your new behind Be great to see before (Rottec) and after
  #35
Old 03-03-2012 | 11:54 AM
dianic's Avatar
I just posted them in the relevant thread... HERE
  #36
Old 03-03-2012 | 01:03 PM
Carlitos way's Avatar
Carlitos way is just really niceCarlitos way is just really niceCarlitos way is just really niceCarlitos way is just really niceCarlitos way is just really nice
So the conclusion is that it is not possible to have the full light patern on when braking?
  #37
Old 03-03-2012 | 01:06 PM
dianic's Avatar
I am sure you can, I am not sure I want to.
Firstly, the outcome is too bright, so it would be wrong.
Secondly, it is not an easy task to change the function to turn off some lights in the middle.
  #38
Old 03-03-2012 | 01:08 PM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Yup - exactly what I do - set the daytime driving lights on (well actually in Canada it's mandatory) so the break lights fade nicely with the rest of the display. Doesn't bother me at all, and it's a MASSIVE improvement over the OEM nonLED and any other nonOEM LED on the market. What a mouthful :P
  #39
Old 03-03-2012 | 01:29 PM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
What do you mean? That is the only view 99% of the other drivers will ever see when my car is moving.
  #40
Old 03-03-2012 | 03:38 PM
rlau1288's Avatar
rlau1288 is infamous around these parts
That is normal for the tail light even the stock does as well
  #41
Old 03-04-2012 | 07:12 AM
sbkim's Avatar
Correct but OEM lights up "C" from the far edge by the fender and actually looks nice. Dectane is an inverted C and seems to end abruptly in the middle of the light. Regardless, looks much much better than stock.
  #42
Old 03-08-2012 | 05:00 AM
PERONE78's Avatar
PERONE78 is a jewel in the roughPERONE78 is a jewel in the roughPERONE78 is a jewel in the rough
i have cut the taillights.... i think it's all OK now... after photos
  #43
Old 03-08-2012 | 06:10 AM
teutonic GT2's Avatar
teutonic GT2 is infamous around these parts
Awesome! Ordered mine
  #44
Old 03-08-2012 | 09:02 AM
What do you mean? you found a solution?
  #45
Old 03-08-2012 | 10:25 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
Hey Perone, did you take your lights apart? pictures!!!!
