Dectane tailights problem
Old 02-24-2012 | 01:03 PM
PERONE78's Avatar
PERONE78 is a jewel in the roughPERONE78 is a jewel in the roughPERONE78 is a jewel in the rough
I have installed the dectane taillights. i have no error but when i push the brake, the led light up like "C shape". i want, if is possible, when i push the brake the led light up completely.
do you have a solution???
thanks
Old 02-24-2012 | 01:52 PM
Doc GTO's Avatar
Doc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond repute
thanks
I believe that this is normal for those tail lights.
Old 02-24-2012 | 03:55 PM
jhbrennan's Avatar
thanks
Normal - can't change.
Old 02-24-2012 | 04:20 PM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
The stock lights do the same. Except the other way.
Old 02-25-2012 | 09:37 PM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Normal, no way to change
Old 02-26-2012 | 09:54 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
I guess the only way to change it, is to find which cables on the tail lights feed the rear fog lights and tap those 2 cables to the cables that feeds the brake lights. that way you will have power going to the end of the lights for the fog light once you press the brake, thus creating a complete triangle, instead of the "C" shape you have now.
Old 02-26-2012 | 10:22 AM
CayenneS2083's Avatar
CayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really nice
I'm surprised no one has tried to do this. It would make the lights look much nicer.
Old 02-26-2012 | 10:45 AM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
I was looking at the all red tailights for my Turbo but when I saw these and googled it they are great. Are they just plug and ply like the original lights or do you have to do some wiring.
Old 02-26-2012 | 01:28 PM
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
I have a feeling only one has the fog light capability. At least that is the regulation. I believe it is on the left...
Old 02-26-2012 | 02:51 PM
jhbrennan's Avatar
Both fixtures must have the light since the are sold in both USA and Europe. It will be the vehicle that's configured right or left based on country. That's why the suggestions for the jury rig are to run wires from the left (in the US) to the right.
Old 02-26-2012 | 03:05 PM
dianic's Avatar
I just got a pair form Dectane Germany, which are still in the box. I will investigate if both lights have connections.
How about cross connecting the wiring for the fog light to the brake light? Same side on each light... Not the car. It is the brake light pattern that needs to change, not the running light, which is a full triangle.
Will try to bench test. More as of Tuesday.
Old 02-26-2012 | 03:23 PM
faiz's Avatar
faiz is just really nicefaiz is just really nicefaiz is just really nicefaiz is just really nice
interested!
Old 02-26-2012 | 06:15 PM
Hmmm - that's an interesting idea!
Old 02-27-2012 | 07:56 AM
JoelPirela's Avatar
That's exactly what I was suggesting... rig the cables on the lights, not on the car's wiring. The hard part should be figuring out the correct cables, after that, is just tapping 2 cables on each tail light for a complete triangle...
Old 02-27-2012 | 01:04 PM
PERONE78's Avatar
I have just try to cross connecting the wiring for the fog light to the brake light.
when i push the brake the 4/5 central led doesn't work...
