suspension noise, HELP
I have a popping noise in the front right suspension when im pulling into parking lots or turning into an entrance. Sounds like ball joints but there perfect, the car is lowerd with TA springs and TA sway bars and thats it. It has 11k miles, any input would help thanks.
Check the strut bushings. If the OE bush was re-used then it is a possibility. If you have adjustable sway bar end links then check to see if that are binding when you turn the wheel from lock to lock.
I had a similar noise develop (more like a thud than a pop) in the front right side - about 6 months after replacing the sway bars. I lifted the car, cranked on the bolt at the end of the sway bar - and noise went away. It was ever so slightly loose. Might want to try that.
I am not sure if I have a similar issue.
When I turn sharp and slowly in the parking lot, I can feel the front tires skipping and tapping. But the dealer told me that this is normal for Porsche 997.1 TT. Does anybody know about this?
Thanks.
Thanks.
proTUNING Freaks
09-15-2015 07:28 AM
