Just a ECU Flash Gives HIGHEST HP Rating
I wanted to reshare our ECU Tuning of the Porsche 997.2 Turbo S. All done via the OBDII port Softronic has taken this 530bhp car to 540awhp on 91 octane. This translates into over 615bhp. In addition to these dyno claims, we can also back up our ECU Flash with extremely strong PBox Numbers from a customers 2010 Turbo PDK as seen below. You cant fudge GPS!
Flash
Flash
- Standard Mode – 541/534
- Sport Mode – 532/524
Since we did not have the stock file in our car when we bought it, we used another customers STOCK file from a TTS. The DFI 91 and 93oct files are the same actually. So what we are going to do is:
- Load the stock file, run the car.
- Load the tuned file, run the car.
- Then add race gas to get 93, run the car.
This will show you actual back to back results. Another tid bit of info, we can also flash a stock non S file to the car and show that stock HP. Stay tuned!
Well the 997.1 Turbo tune is WELL proven
http://www.vividracing.com/catalog/-...9-p-45751.html
Tuning the 997TT alone is a ton of power... All these Turbo Porsches come alive! I believe this car also has our Agency Power Exhaust - http://www.vividracing.com/catalog/s...p-997tt-1.html
http://www.vividracing.com/catalog/s...9-p-45751.html
Dan....Curious if you have any idea what my BHP is with the 997.1 TT now? I only have a high flow BMC F1 filter, Performance headers and the tune (also put the new cooler iridium plugs and new variocam actuators for good measure).
Still loving the tune and no issues at all except burning through new tires too fast! Kudos to you and Scott...Your service was great!
DC
Thank you so much. A 997.1TT does about 400awhp on our Dyno. I would factor your at maybe 480awhp which is 580-600bhp. Since you have 93oct tune its better then my initial test with 93. The biggest help now for you is the exhaust. The stock exhaust and the 400cell cats is very restrictive. It robs alot of the top end power.
