1/4 mile. How did I do?
I was holding it at 3k and then slipped it a tiny bit. I would have tried a higher dump but I was worried the oem clutch wouldn't hold. I imagine if I spun my wheels some off the line I might get a higher trap speed?
your launches are good. but i think you should be able to get faster traps with a better tune perhaps. your 120-121 traps are a bit low should be in the mid to high 120 range.
#TeamAIM
#TeamAIM
my 996 turbo x50 with flash and exhaust did 125 mph, i think your times are low overall, i would change my tuner in your place and refund everything, I think stock 997s hit around 120mph, did you hit soaked your car ? Conditions ?
If that car is MT you are a consistent and a hell of a driver, if AT you're ok also
So driver ok, mods ok, tune not IMHO
good luck !
good luck !
Spin that baby up to 5500 and slip it till she grabs.
Damn noobs.
