Power Window Question
Old 05-09-2012 | 12:57 PM
911t-gts's Avatar
911t-gts is infamous around these parts
I'm having an issue with the auto-up feature on the passenger side window. It works going down and in both directions when operating the convertible top, but have to hold to go up from the drivers side switch. As I'm writing this, I realized I haven't tried it from the passenger side switch so I'll try that when I get home. Any other suggestions?
Old 05-09-2012 | 01:10 PM
ECS Tuning - Porsche's Avatar
Push the window switch up until it closes. Continue to hold the switch up for 15 seconds. Resets the memory.
Old 05-09-2012 | 01:17 PM
boxingsfinest's Avatar
boxingsfinest is infamous around these parts
Same issue as well. I have to hold the button up until the window reaches half way then double tap for it to auto up.
Also have the window streaking problem that i cant seem to find a solution for, any rain or car washes leave streaks on the inside of the windows any time i put them down. Any advice for either would help.
Old 05-09-2012 | 01:18 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
I have a coupe with the exact same issue. Durametric barfs an error code for that (and my driver's seat). Something to do with parameters being out of range. I figure the switch has gone bad, but am open to ideas?
Old 05-09-2012 | 01:56 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I don't think the passenger windows has auto up 07 and up for safety.
Old 05-09-2012 | 05:08 PM
jhbrennan's Avatar
Cab does.
Old 05-09-2012 | 07:10 PM
512bb's Avatar
The coupe driver side, in my 2007 TT is "one touch" down and up. The passenger side is "one touch" down, but going up, I have to hold the switch in the up position, till about the window is half way up and then it will go the rest of the way. At some point I will dig into it, to see why I am getting the error!
Old 05-09-2012 | 08:01 PM
alterra16's Avatar
alterra16 is infamous around these parts
The owners manual for my 12 TTS says the passenger window has to be 1/2 way up before auto up feature works. However, I was told by the dealer that the windows have a very sensitive pinch protection mechanism that will stop the window with even a hint of resistance. This requires adjustment of the window. Also, Porsche had installed windows which were too thick in some cars, leading to continuous pinch sensor stoppage. My previous Carrera S had the passenger window replaced with a thinner window. Problem continued. I traded the car and on this one saw the above suggestion in the manual.
Old 05-27-2012 | 04:38 PM
911t-gts's Avatar
Just a quick follow-up on this... I tried all of the suggestions without success. However, in my attempts, noticed that the passenger window auto-up was working when the rear passenger window was down but not when it was up. So I tried the ECS Tuning suggestion on the rear passenger window and that did it. The front passenger window auto-up now works with the rear window up or down and the top up or down. Thanks for all the feedback...
04-28-2022 12:38 AM
r_matt_6
10-08-2015 06:07 PM
gulf gt
08-27-2015 10:27 AM
08-19-2015 06:55 PM
Quick Reply: Power Window Question
