Blue demon from Russia with love :)
#167
Tomorrow I m coming with Gakis to Moscow for the Unl 500 ...I want a fast ride with your car!!!
#170
Turbos gtx3582 0,63 ar
AMS IC with custom built 3" stock air box system
It's cold now in Moscow, about 13C, IAT max is 42C and it drops to 20 very fast
Thx Yousef
Btw it's legal road, not drag strip, tire pressure is 2,4 bar rear and 2 front
#171
I thibk if u stroke ur engine it will be way way better ,
Am going to test my car in QATAE mile in the end of this year , i just waiting new SUSP mods and some tweeking om the camshafts !!! Hope to do well
Good luck buddy
#173
1.7bar on pump or there is a typo ? how would you compare Syvecs to stock tuned ECU ? i mean boost for boost ...
#174
Built engines can handle a lot of boost with a good tune.
#175
boost should offer more power than timing, i dont know why our tuners dont use more boost with less timing, and i know it should be a good answer for that...
that 4.1 liter engine should have a very low compression that's why is so "boost tolerant", i wouldnt run 1.9 bar on stock compression engine with less than C16/E85...
#176
Also there may be more agressive ignition
#177
I have on 1.7 bar, after turbo spooled up, 20-22 degrees and 0,78-0,75 lambda, leaner fuel wont effect on power, maybe 5-10whp but it will dramaticaly increase EGT.
Btw on stock ecu max ignition angle that i saw in my logs was 18 with same lambda... so there is the difference betwen syvecs and stock ecu
#178
Hey Megion, just a few questions.
Are you running additional fuel pumps?
Can you start to explain how the Syvecs can possibly make the mechanical parts in the trans shift quicker? I find this hard to believe..
Id like to do your setup in the near future but want to avoid any drivability issues. How is the car at low speeds in traffic? Any bucking or difficulties just cruising?
Cheers
Cheers
#179
I want to chime in to write my experience with several things.
Stock ECU vs Syvecs, i don't believe there is obvious power difference with Syvecs vs Stock. I can run 26deg timing with stock ecu if you want. Thats not a problem.
If you adjust same ignition, same boost, same lambda, same cam timing, there isn't anything else to create more power.
BUT, Syvecs is just much more flexable, regarding map switching, several other control options, more map resolution etc... Gives you more room and features to play with. So you can get more out of your car.
Regarding shifting, i didn't have any shifting delay problem with stock ECU and it shifts quite fast. see below,
However, i would also like to see our Tip upgrade together with Syvecs which uses different fuel and ignition strategy between the shifts.
High boost on pump gas, it depends on your tuning strategy and its directly related with fuel quality.
So you have to optimize your engine build according to your customers driving and fuel options. You can't compare Apples to Oranges.
ESMOTOR
Home of the Worlds quickest Porsches
1/4 mile: 7,95 @ 190 mph
100-200km/h: 2.16 sec
200-300km/h: 3.43 sec
60-130mph: 2.52 sec
100-150mph: 2.19 sec
Email: emre@esmotor.com.tr
Web: http://www.esmotor.com.tr
Instagram: http://www.instagram.com/esmotor
ESMOTOR
60-130mph: 2.52 sec
#180
Megion -- Are you running the OEM AWD setup or have certain parts been upgraded (Diffs, Transfer Case, Axles, Drive Shafts, etc)?? Just wondering how it's handling the power & repeated race use (dig launches, roll racing etc)
