Blue demon from Russia with love :)
#31
What was the weather temp while IAT was 65??
Double check your cooling system completely ( Radiators, water hoses/lines.......etc)
What about the aftermarket front and rear bumper? couldn't effect air flow?
Are you sure you cut the Intercoolers ducts as your tuner recommend? that can be huge IAT factor
#32
That IAT is really weird. We are using same turbos kit ( same coolers and exhaust ) in much hotter climate ( 40-44c at night ) and we never saw IAT like yours.
Temperature about 25-28 celsius
All hardware is fitted properly. I don't know, we will check IAT with new setup
#33
That's very low temp vs IAT. We usually saw IAT 10c ( approx ) more than weather temp.
Both Kentusha and DMY rans pretty fast with no problem on stock engine. Could be something wrong with tune or build ( like cam timing degreeing off ) can cause quick overheating also.
#34
Kentusha has stock internals, it's not mechanical problem
Mb its:
1. Restrictive exhaust, big back pressure and overal overheat
2. Bad air flow through IC
3. Something wrong with ECU
Mb its:
#35
Goodluck gents
#36
bro , i faced the same issue before 2 years ago , very high IATs even if outside temp is 15c or less !!!! when i checked my system it was one of my external WG was not installed corractly , i forgot to install the wastgate valve seat into the WG so wastgate was leaking flow ,
what happend is when i turn the EBC for high boost , the EBC will make the turbo spool much alot to give the target boost and compensate the boost leak , and this will make the turbo temp very high !!!! hope you solve your issue and fix that
#38
Car is ready!
Guys, what can i say... I made some tests on old software (for alpha 30) Its launch very hard 0-100 km/h 3 sec on pilot super sport +14C (pump gas and passenger in car)
100-200 km/h 4,7 sec (pump + 1 100kg guy)
Boost 1.45 bar (21 psi)
Spool... its fantastic! Like on old setup, full boost on 4500 rpm
Its realy DD car with GTX3582!!!
I found only one bad side... exhaust is too loud! ITS EXTREMLY LOUD!
New tests on C16 soon! Stay tuned![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
![](http://cs302401.userapi.com/v302401695/2b3f/MGfL8jez-Pg.jpg)
#39
Car is ready!
So no more high IAT issue?
You should be 4.2-4.3sec range without the 100kg passenger
We need some 0-300kmh or 100-300kmh results
Goodluck bro
#40
New air intake and 4" exhaust rulez
Tomorow i will test new software on high bost (1,7 bar or 25 psi pump gas)
Expecting 4,0-4,1 sec 100-200 and 200-300 about 9 sec
#44
Some tests on C16 fuel, boost 1,7 bar (25 psi)
Night, +15C, cold road
0-100 2,6 sec
100-200 4,2 sec
200-300 dont look, it was in traffic, i had to release and push pedal.
And quartermile 9,9... I hope to run 9,5 with good conditions
![](http://a.d-cd.net/cc1194u-960.jpg)
0-100 2,6 sec
100-200 4,2 sec
![](http://a.d-cd.net/1c1194u-960.jpg)
