Hard starting - WHY
Old 09-01-2012 | 09:52 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Hard starting - WHY
speeders , i have a weird problem happend with me when dealer workshop dropped the engine to fix a coolant leak ,
when the engine is cold , its hard to crank it , it took 3-4 sec to start !!!! sometimes it does not start !!! it cranked from the 2nd try to switch it ON !!!!the weird thing is when the engine is warm its cranked normally with 1 sec or les !!!!!!!!!
is it spark plugs issue ?? as i did not replace them from 2 months
is it fuel pump issue ??
it the return fuel line ??
is it bad injector ?? as i used them for allmost 2 years now !!! i cleaned them by special tools before this problem happend , so mybe the Siemens injectors is not cleanable ????
or what ??
thanks in advance
btw .. no codes i can see from the durematric reading
Old 09-01-2012 | 09:59 AM
gmoney's Avatar
Original battery? If so your on borrowed time, replace it.
Old 09-01-2012 | 12:03 PM
bbywu's Avatar
Yousef,
Even if the engine turns over, a bad battery can cause electrical gremlins on startup with sensors and the ECU.
When the car starts, does it idle ok or is it rough?
You're still running MAFless right?
Old 09-01-2012 | 12:14 PM
ysfg35's Avatar
the battrey is new , bought it before 3 months !!!
and when its start idel is fine and car is running well :s
and yes my tune is mafless
Old 09-01-2012 | 12:36 PM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
Mine had cranking issues when I had the clutch replaced. They had to open the tranny back up and adjust the specs on the crank position sensor. It has a very fine amount of adjustment I guess.
Old 09-01-2012 | 01:28 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
I would check that battery again.... you never know with a Porsche battery, they EAT those suckers.
LOL
Old 09-01-2012 | 04:17 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
try to replace your crankshaft position sensor.it can be easily damaged when droping the engine.
Old 09-01-2012 | 04:43 PM
sharkster's Avatar
Maybe the ignition switch??
Old 09-02-2012 | 05:58 AM
ysfg35's Avatar
if the crank position sensor faild it will give a code , the weird thing is when the engine is warm it ran fine and no hard starting at all !!! someone told me it may be the return pump line !!!!! still do not know
Old 09-02-2012 | 07:14 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
I think its the injectors, i had the same problem in 3 cars here.
The problem is that you cant see it in diagnostics. you have to change them.
ESMOTOR
Home of the Worlds quickest Porsches
1/4 mile: 7,95 @ 190 mph
100-200km/h: 2.16 sec
200-300km/h: 3.43 sec
60-130mph: 2.52 sec
100-150mph: 2.19 sec
Email: emre@esmotor.com.tr
Web: http://www.esmotor.com.tr
Instagram: http://www.instagram.com/esmotor
Old 09-02-2012 | 08:16 AM
ysfg35's Avatar
thanks emre , even the dealershop told me injectors faild
ok i saw many SIEMENS 80lb injectors , do anyone know which one will fit the 997 turbo ? whats the part code ?? or all the SIEMENS 80lb injectors are the same ?
i read that SIEMENS have 2 kinds of ( Long Style ) injectors for the 80lb but one of them come with EV1 Connector , the other come with USCAR EV6 Connector
so which one will fit ?
Old 09-02-2012 | 10:46 AM
SeattleBum's Avatar
Mine never failed, and never through a code. I was told the tolerances are so tight on that sensor that just the slight expansion and contraction of the metal put the sensor out of whack.
Anyway, once they adjusted the sensor, I had no hard starts or cranking issues. Hope you figure it out!
COBB Tuning
03-29-2016 10:26 PM
RallyBird
10-07-2015 02:20 PM
Mark @ AIM Performance
09-22-2015 10:17 AM
SRC4S
09-01-2015 10:22 AM
