Not hitting max boost...
Went out for a spin today and noticed that I'm not hitting full boost under full throttle under any conditions; freeway pulls, 35-70 pulls... I'm at about 0.7-0.9, when I should be getting 1.2. It goes up quickly and then seemingly hits a wall. Is this normal?
I feel like I remember the car going all the way to the limit of the boost gauge in the past. Could I have a boost leak? Engine was up to temperature, and weather is about 68°F and 64% humidity.
good clarification, not familiar with the Turbo S
It's a relatively inexpensive fix if that's what's wrong. Might not even be a bad idea to replace them even if they're OK now...eventually the stock ones will start to fail. I've got 'em in stock. http://www.championmotorsport.com/pr...p/cmsdv02b.htm. Just keep in mind, for your car, you need 2.
Thanks Tom. I'm curious, what are the physical differences between Turbo and Turbo S? Did they change any other hardware for the extra 30 hp?
PM me an email address and I'll send you the Porsche product guide for the Turbo S (it's a big pdf file).
