ESMotor 4.1 Liter Porsche 997 Turbo First Results
Tonight I made some more testing, opening the boost progressively following Emre's advice.
on 1.6 bar it did 3,47 seconds 100-200 kmh and 4,06 60-130 mph on almost a flat surface (less than 1% downhill) Same 22 degrees celcius weather.
Will do the tests on 1,8 bar and 2,0 bar in the next few days, I will keep you guys posted.
Here is a little image to tease
Regardless, his car is a beast and just might hit low 3's. Good luck!
That's why they run meth injection. Turns pump gas into race gas.
GT35s need more fuel to support the extra flow *
I did not know that the 1100cc injectors only with stock fuel system (pumps- rails-FPR) is enough to support fueling .. ! *
Congrats buddy .. Mashala mashala*
