996tt fault codes
Hello the codes that you have are as follows
P0171 is a lean mixture code due to a vacuum leak somewhere in the intake system.
P1109 is a boost leak code most likely due to the vacuum leak.
Most likely you have a boost hose that came off or has a leak in it.
