Putting my Car away for the Winter - Tips
When I put my car away for the long winter nap I:
1. Change oil and filter.
2. Put desiccant packs inside the trunk and on the driver and passenger foot wells to eliminate moisture inside.
3. Put 50 psi of nitrogen in each tire.
4. Put Sta-bil in fuel and drive for at least 30 minutes to mix it and heat oil to get rid of any moisture.
5. Remove wiper blades and put Styrofoam under wiper arms where they touch the windshield.
6. After engine cools put plastic bags over exhaust tips.
7. Clean wheels, brakes, and tires.
8. Connect Battery Tender on battery
9. Cover and don't touch it until next spring.
I would also add to the list:
10. Leave windows opened by 1inch for air flow and to keep humidity out of the car.
11. Keep your garage's temperature around 60-70 degrees
I also add mouse traps around the car.
So you think its ok to leave the dirty carbon, alkalies, and acid contaminated used oil in your TT over winter? CHANGE THE OIL BEFORE YOU PUT IT AWAY FOR WINTER!!!!!
PorscheEnthusiast
11-13-2015 03:23 PM
RS GT3 RS
09-24-2015 10:27 PM
