Coolant smell after driving
I am noticing a coolant smell usually after driving my car for a while. I haven't noticed any white smoke or leaks on the floor where the car usually parks. Also, I have not received any warnings, stating low coolant levels.
Has anyone else experienced this? This is an 07 Turbo. It seems like the smell is coming from the rear.
Thanks in advance.
Vin
Thanks in advance.
Vin
Yes i had the same problem with the coolant smell and found it to be the front radiators. My car is very low mileage so thought it was ok but when the front bumper was removed it was found that water was sitting on the bottom of the radiators and caused then to corrode and leak. Apparently a common issue. I had to replace all the radiators. I would expect your turbo to be similar to the GT2 set up regarding the radiators but not sure. I would recommend checking the radiators to be on the safe side and then hopefully cancel this out.
I had the same but after a few days I could see white smole from the rear when parking. It the developed into a slow dripping of coolant. It actualy took weeks before it developed into a steady pour of water...
Two hoses on the right side of the car needed replacement, the engine had to come out, and I was very happy for my extended waranty.
Mine is also a 2007 turbo...
Oh man...I think I am going to puke.
Upon purchase of the car, one of the radiators was replaced because it was leaking. I purchased the car in September and have only put around 600 miles on it. Initially I thought it was spilled coolant burning off when they did the radiator. However its now close to four months and I am still getting the smell.
-Vin
-Vin
-Vin
Check the coolant reservoir cap. - the seal "sets" and under pressure leaks a bit. A new cap at $26 may be the answer
If that rubber hose was covered.....what is the name of your extended warranty co....I would like to purchase it.
You are saying above that your extended warranty paid for two hoses which involved pulling engine. My extended EasyCare warranty which is one of the best in USA refused to cover a water hose, 2 inches in length, saying nothing with rubber is covered. Maybe factory covers this but not EasyCare or any other extended warranty is what they said.
The seller had to make sure the car was in compliance with a long list of "rules" that Porsche dictates incl N-marked tires (I actually have a set of brand new Micheline PS that didnt have the N-marking).
I do not think it is possible to purchase this coverage. It isnt easy to sell thoose cars in Sweden and the warranty offered was one of the main reasons for me to get this specific car.
Thanks, I will check it. This is definitely a possibility.
nlakind
11-06-2015 10:15 AM
LiquidElephant
08-27-2015 06:17 PM
