APR tune 93 oct vs. 100 oct race tonight. Me vs. blackswan
Quick, no it does not. You should get an overboost arrow in sport mode...do you? I had intercoolers installed and was only getting 8 psi...turns out there was some electronic connector that was loose. I dont know what it is because i did not do the install and im not a mechanic. After that was fixed 17+ arrow. At 8psi my car was slow.
Due to all the respect to our good APR 100 oct tune,
My car being 93 oct APR tuned car (dispute that I have GT2RS intercooler and catless exhaust system) versus, his car having IPD plenum + Ypipe + Fabspeed intake,
The race was pretty close..
The # showing on APR site saids it's about 70 hp more, but how is this possible?
I did some runs with 93 and 100 and VBox times confirmed there were some differences. The car had the exact same mods and I did the runs at the exact same spot. The only difference is it was about 40F with the 93oct and 60F with the 100oct.
60-130mph, 7.9 1 shift
100-200kmh, 6.3 0 shift. 6.6 1 shift
60-130mph=7.5
100-200kph=5.9
Another thing to keep in mind is that the APR tune is the same no matter what mods you have, it doesn't change as your mods change. So I'd imagine the intake, plenum, Ypipe, headers...etc are not doing much. Your GT2RS coolers might actually make the most difference since it'll help keep your IAT down and your times more consistent.
60-130mph=7.5
100-200kph=5.9
60-130mph=7.5
100-200kph=5.9
60-130mph=7.5
100-200kph=5.9
That's good stuff. Thanks. What do you think would be the reason he is seeing 17psi+ and arrow? As i am only seeing 15psi and no arrow.
![Confused](https://www.6speedonline.com/forums/images/smilies/confused.gif)
If I am on the stock map and able to hang with blackswan, my car will be a superstar!
Haha that is super weird. Let me change maps around and see what happens.
I just spoke with APR tech support and i am going to try to repeat what they just told me.
1. We are seeing different boost levels because each car and computer are different depending on what car and modifications, the computer will use more or less boost to achieve the power output given by the program.(that is my abbreviated version of the smart talk)
I can't find any other reason why the boost levels would be different but they seemed to be very confident that is what is going on.
2. The programs we are using are specifically for a cat-less exhaust system and will significantly make a difference without a cat. Says APR.
I will be ordering my cat-less X-pipe very soon. We can find out what is what.
3. I am at a loss if none of this makes sense.
And the catts must create more back pressure than a cattless setup, so without them the APR folks can be more aggressive knowing your turbos will be a happier, allowing for more boost.
I am new to the P-car tuning and the little I know comes from a few years of BMW N54 tuning, that engine is slightly different (I6 and high compression using DI).
