997.1 stock alignment specs??
I've searched this forum and googled some and can't find what I'm looking for. Can someone either give me a link or the actual specs. I want to double-check the specs my alignment guy is using. I want to re-align with minimal rear camber and toe to maximize tire mileage. (but will remain within the range)
Factory specs as listed:
Front
Camber: crap
Toe: crap
Castor: Fixed
Rear
Same as front
LOL.
Most likely your rear toe is to far in on both sides. I don't have factory specs but to much toe is usuallt the main issue. Good luck!
Front
Camber: crap
Toe: crap
Castor: Fixed
Rear
Same as front
LOL.
I've seen different specs from 2 shops, so I'm looking to settle this on my own now.
Interesting advice that I haven't seen before. I've seen it recommended to get the rear toe down to .1 degrees for the best overall results. (balance between wear and handling)
.1 is about as "low" as you want to go. Due to some errors on an alignment, caused by having 20" wheels, the rear toe on my car ended up being about .1 toe out on the rear.
When the rear would catch the ruts it would be over steer when going straight. Not a fun feeling or dynamic when you are bolting down the highway.
Question.
I've a dozen alignments on various racks,.. and done perhaps 50 with lasers or strings,.. and I've never run into specs listed this way.
The chart above shows toe for the rear as 10 feet? +/- 5 feet?
What is that spec,.. it makes no sense.
Can someone help me out?
Are they perhaps using the apostrophe symbol to refer to MOA (Minutes of Arc)?
If so,.. 10 MOA would be about 0.17 degrees. and the +/- 5 would give a range of 0.083 to 0.25 degrees tow in per wheel.
Total toe-in of .16 to .5 degrees.
https://www.6speedonline.com/forums/...red-turbo.html
The question is though,.... what does 10' mean for rear toe?
Obviously not ten feet.
Wheel Alignment Specifications are normally given in angular values
of degrees and minutes.
A circle consists of 360 segments called DEGREES, symbolized by the
indicator °
Each DEGREE again has 60 segments called MINUTES symbolized by
the indicator ‘.
Therefore, for example a ½° (Degree) is also the same as 30’ (Minutes)
and ¼ ° (Degree) is the same as 15’ (Minutes)
Angular values are popular in that they are not reliant on wheel sizes
(rims), nevertheless in certain instances the values of TOE are given in
Millimetres. When this format is used then it is imperative that the wheel
sizes (rim) are known, simply for the fact that as one moves away from a
given point on the wheel (normally the centre) then the millimetre value
will increase the further one moves off the centre. If the wheel (rim) size
is used then the point of measurement becomes fixed.
DC
04-28-2022 01:38 AM
oddjob142
08-19-2015 01:27 PM
