BMC Air Filter
#76
I still go back to posts #8, #16,#19, and also #23 which has a negative tale to tell. https://www.6speedonline.com/forums/...r-4-gt3-2.html
I see no issue with SW's packaging of a product group but those graphs clearly stay away from isolating the BMC filter, instead use all 3 items....but actually quote the two items only during the test.
Same applies with Porsche or RUF packaging their car with the filter and racing stripes....nothing wrong with that at all, they are appealing to a particular demographic so they package the product in a way to be as appealing as possible, but there is a vulnerability for the user maintaining that item. Frankly if i were buying a GT2RS 4.0 the first thing i would do is change the filter to the Mahle paper unit....that's just me. You see if you get to see broad daylight through the holes then that (to me) is "nuf said" where the entry of particulate is concerned. Why would the particulate bypass going through these open holes when that is the path of least resistance?
And for good reason going by your own lengthy and meticulous procedure. How many would go to the trouble of doing this?...or, would bother? And, at what stage do you really know when its time to do the job? Too many variables and vulnerabilities imho. My own experience with these filters is they get filthy so quickly....and there are holes you can see broad daylight through particularly after the cleaning process with or without the use of compressed air.
Given an OEM Mahle can be quoted as being available for as little as 20 USD which at $150 is nearly 8 OEM filters worth, or at $235 is nearly 24 OEM filters worth i ask why would anyone bother, least of all run the risk of particle contamination of their expensive PT engine regardless of how small it may well be found at one point.....although lets be honest here, that really depends upon the operating environment and the ability to maintain a proper cleaning regimen (at exactly what stage or point in time yet to be actually defined).
#77
Dunno...Alex doesn't seem like a racing stripes kind of guy.
Serious though, if the MAF sensor were sensitive enough, I'd log a high speed run for you with a paper element then with a cotton element to show the difference. This argument has been fought on every forum, with every platform, with every tuner. I feel like I'm back to my Acura Integra days.
#79
I absooutely get it and wasnt exactly taking sides as I dont know nearly enough about the Porsche specific parts being discussed here. My point in posting was just to point out that IF you have spent or plan on spending a couple hundred dollars in a washable filter there are ways to keep the maintnance part on the straight annd narrow. Albeit..tedious and time consuming.
#80
rats.. s'werks.. i just went full circle again whats not to like about that ( lack of ) airbox.. arghh.
i've been looking today at my k&n cones on my old triumph. i think there's a lot more filtration going on in them, relative to the flat panels. they're virtually the same as that gt3. whatever.. it would be a $1500 experiment and i have a brand new $20 mahle now...and all is good.
